valve adjustment needed after ITR cams install?
Old Oct 22, 2001 | 01:47 PM
1fastGSR's Avatar
New User
Default valve adjustment needed after ITR cams install?
I installed ITR cams in my GSR with 20k miles. I was told that I did not need a valve adjustment because my car only had 20k miles and also because the primary lobes were the same for the GSR and ITR cams.
I was looking at the Hlems manual and noticed that none of the lobes were the same.
Was a valve adjustment really necessary?
[Modified by 1fastGSR, 5:41 PM 10/22/2001]
Old Oct 22, 2001 | 02:03 PM
IN VTEC's Avatar
Default Re: valve adjustment needed after ITR cams install? (1fastGSR)
I think you should have at least checked the clearances before buttoning it up and driving off.
Old Oct 22, 2001 | 02:05 PM
owen_the_soyboy's Avatar
oh hell yes you should do it.
no question.
Old Oct 22, 2001 | 02:10 PM
smerk's Avatar
New User
ya I would have definitely done the valve adjustment if only just to check the clearances. Were you in a hurry or something? It just seems odd to install new cams and not do a valve adjustment at the same time.
Old Oct 22, 2001 | 02:44 PM
stick's Avatar
anytime cams are involved u should adjust them for proper clearances
BTW, specs are the same for GSR and ITR according to helms
Old Oct 22, 2001 | 02:52 PM
blktyper2001's Avatar
New User
Default Re: valve adjustment needed after ITR cams install? (stick)
You should check them, sometimes you need them.
Old Oct 22, 2001 | 03:23 PM
1fastGSR's Avatar
New User
Stick,
the valve clearances are the same, BUT the cam lobes are NOT the same for GSR and ITR, right?
My friend said that the PRIMARY lobes were the same and I did not need a valve adj.
Old Oct 22, 2001 | 03:30 PM
Malice's Avatar
New User
get the valve adjustment!
Old Oct 22, 2001 | 05:06 PM
HKxBlur's Avatar
I'd like to put this topic to rest REAL QUICK.. This weekend, I installed 2k ITR cams in my GSR and I, too, was told that the adjustment was NOT necessary.. I still went and bought the valve adjustment tool from a Snap-On truck for $40 cash and bought angled feeler gauges for under $7..
I changed the adjustment on at least 2 (out of 4) lifters on every cylinder.. It is ABSOLUTELY necessary, and should always at least be checked for a $6 part (feeler gauges).. btw, I laughed when I saw the above post about the primary lobes being the same, basically meaning only the VTEC lobe is different.. Why buy the cams then? heh
Oh, and if u dont do the adjustment, since the ITRs aren't that radical, your new cams will break in wrong and then grind away to GSR specs.. If the cam was crazy radical, piston-to-valve clearance would be compromised and you'd have bent valves right away..
Old Oct 22, 2001 | 05:10 PM
Zulu888's Avatar
Default Re: valve adjustment needed after ITR cams install? (HKxBlur)
how exactly do u do a valve adjustment?
Old Oct 22, 2001 | 06:48 PM
1fastGSR's Avatar
New User
i know all the ;pbes are different because I looked in the Helms!!
Old Oct 22, 2001 | 06:59 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
I believe the primary lobes are the same and that the VTEC lobes are the ones that are going to be different. You buy the cam because the VTEC lobes are bigger. That's where the power comes from, not the primary lobes. Those are for fuel economy and cruising around town. The bigger secondary/VTEC lobes are for higher HP up top when you rev high, ie - racing.
Old Oct 22, 2001 | 08:41 PM
C-speed's Avatar
Default Re: valve adjustment needed after ITR cams install? (Zulu888)
Yes, anytime you swap cams, you must adjust the valves, here's how to do it:
http://www.c-speedracing.com/howto.html
Old Oct 22, 2001 | 10:10 PM
PROFILES2000's Avatar
Default Re: valve adjustment needed after ITR cams install? (G3-TEG)
just food for thought valves should be adjusted every 15,000 miles under normal driving conditions.....normal driving conditions do not include red lining a lot so i am sure most people here would have to do it more frequently
Old Oct 23, 2001 | 07:24 AM
Phat Corolla's Avatar
New User
Default Re: valve adjustment needed after ITR cams install? (PROFILE GSR)
Yeah, I do mine every 10,000 or so. It's a good idea, and it doesn't take that long. I bought the Snap-On valve adjustment tool for $45 and it makes it wayyyyy easier. Cspeeds site is a wonderful resource you should utilize.
jceltalentoso
K Series
Jan 27, 2014 06:45 AM
azandford
May 14, 2010 09:09 PM
Slow_import
10
Nov 16, 2006 04:00 PM
4U2NV
Dec 22, 2003 05:05 PM
Chugger
Jul 25, 2002 03:19 AM
