Where and/or how to check tranny fluid?
Old Oct 22, 2001 | 11:52 AM
Chip398193's Avatar
New User
Default Where and/or how to check tranny fluid?
It says is the manual to just unscrew the bolt on the tranny filler thing, and feel for fluid. It shows a pic of where it is, but i cant find it. Can someone tell me where it is? Thanks
Old Oct 22, 2001 | 12:16 PM
LostGsr's Avatar
Default Re: Where and/or how to check tranny fluid? (Chip398193)
The fill hole is behind the cv boot. Unscrew the plug and if your car is level there should only be drips coming out. If not, fill it till a little flows out. Heres a pic from http://www.C-speedracing.com
Old Oct 22, 2001 | 06:57 PM
DamonBoost's Avatar
New User
Default Re: Where and/or how to check tranny fluid? (LostGsr)
How does your car/tranny respond if you are low on fluid?
Old Oct 22, 2001 | 07:27 PM
Big Teggie's Avatar
Default Re: Where and/or how to check tranny fluid? (Damon501)
If you are low on fluid the gears are very choppy and its hard to get into gear. You can tell, its a big difference with fluid then without.
Old Oct 22, 2001 | 07:42 PM
DamonBoost's Avatar
New User
Default Re: Where and/or how to check tranny fluid? (Big Teggie)
Would it cause grinding when shifting at high RPM's?
Old Oct 22, 2001 | 08:35 PM
vtecdc2's Avatar
i think grinding when shifting is your syncros...
Old Oct 23, 2001 | 11:36 AM
skafia's Avatar
25 Year Member
Default Re: Where and/or how to check tranny fluid? (HoL Lee SHieT)
I just got a new clutch within the past 6 months, I was wondering I'm sure they checked/added tranny fluid, how often would you need to check it?
Old Oct 23, 2001 | 01:47 PM
Phat Corolla's Avatar
New User
Default Re: Where and/or how to check tranny fluid? (skafia)
To replace the clutch, they had to drain the tranny fluid, so i'd say its a good bet that you have new fluid in there.
97CWITR
Jul 18, 2011 08:05 AM
fsufreak08
Aug 16, 2008 06:04 AM
fanta!
12
Dec 30, 2005 06:59 AM
magic hat #9
Sep 30, 2002 07:25 PM
01-1293
Jul 9, 2002 08:34 PM
