HONDATA RELATED QUESTION
My ecu is socketed and i was wondering if i took my hondata out (returning my car back to stock) will it be okay to drive with or will i run into problems?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dabrown »</TD></TR><TR><TD CLASS="quote">You would still need to cut a jumper to return the ECU to it's stock form.. </TD></TR></TABLE>
How do i do that?
How do i do that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oemDC2 »</TD></TR><TR><TD CLASS="quote">
How do i do that?</TD></TR></TABLE>
Bump
Bump
How do i go about doing this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ »</TD></TR><TR><TD CLASS="quote">Jumper J1
-PHiZ</TD></TR></TABLE>
Kyle says i will need my stock EEPROM
The actual hondata unit is, but the stock EEPROM had to be removed and the EEPROM that hondata provided were soldered in so the hondata can plug up to the ECU..
On OBD1 ecus, jumper J1 controls weather the ECU loads a program from an external EPROM, or internaly from the MPU. If J1 is not jumpered, the ECU will load it's program internally from the MPU, i.e. "stock"
-PHiZ
-PHiZ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ »</TD></TR><TR><TD CLASS="quote">On OBD1 ecus, jumper J1 controls weather the ECU loads a program from an external EPROM, or internaly from the MPU. If J1 is not jumpered, the ECU will load it's program internally from the MPU, i.e. "stock"
My ECU was prepped by Hondata, I think they had to unsolder my stock EPROM and resoldered a EPROM they provided. If the J1 was not jumpered, will the ECU be stock at that point? My ecu is OBD1..
