38mm tial wastegate fit on manifold made for 35 mm?
whats the difference between the tial 38mm low pressure wastegate and the 38 mm high pressure wastegate? on NO LIMIT MOTORSPORTS website they have tial 38mm Low press wastegate for 215 dollars with spring choices from 7 psi to 14 psi and then the tial 38mm HIGH press wastegate with spring options from 15 psi to 23 psi... is the difference just the spring choices or is there a actual difference in teh wastegates?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy »</TD></TR><TR><TD CLASS="quote">whats the difference between the tial 38mm low pressure wastegate and the 38 mm high pressure wastegate? on NO LIMIT MOTORSPORTS website they have tial 38mm Low press wastegate for 215 dollars with spring choices from 7 psi to 14 psi and then the tial 38mm HIGH press wastegate with spring options from 15 psi to 23 psi... is the difference just the spring choices or is there a actual difference in teh wastegates?</TD></TR></TABLE>
bump
bump
