Civic Proportioning valve and master cylinder use on Prelude!
Old Mar 23, 2004 | 12:59 PM
killa_lude's Avatar
Default Civic Proportioning valve and master cylinder use on Prelude!
i trying to redo the 2 brake lines from the master cylinder to the prop. valve, and i need to run steal braided from the master cylinder because of my ge intake mani...anyway i cant get 12mm 1.0 thread pitch lines (or fittings) , so im wondering if i can run a civic M.C. and a prop valve...(10mm 1.0 t.p.) so i can run these lines. Will my h22 prelude breaks work fine if i do this?
Old Mar 23, 2004 | 07:49 PM
killa_lude's Avatar
Default Re: Civic Proportioning valve and master cylinder use on Prelude! (killa_lude)
anyone here?
Old Mar 24, 2004 | 07:24 AM
killa_lude's Avatar
i know you all think it would be really stupid, but would it work or not?
Old Mar 24, 2004 | 11:34 AM
prelittlelude's Avatar
i dunno man thats a tough call, so why won't the stock s lines clear your manifold?
i don't think a civic MC can push as much fluid as a lude one, hence the smaller size all around, it might work, but you might have to put it to the floor to get it to work, or it might work fine.. thats hard to say..
how far have you gotten witht eh swap over to non abs?
Old Mar 24, 2004 | 12:17 PM
flyrod's Avatar
Default Re: Civic Proportioning valve and master cylinder use on Prelude! (prelittlelude)
I think the prelude master cylinder is bigger. It might not bolt to the booster, and if it does the brakes would probably feel spongy. Give it a shot, just be careful...
Old Mar 24, 2004 | 04:40 PM
user 9782082308's Avatar
Maybe I'm not understanding correctly, but why not cut the old lines so you can scavenge the fittings and get some hard brake line from Advanced and make your own?
Old Mar 24, 2004 | 05:33 PM
killa_lude's Avatar
Default Re: Civic Proportioning valve and master cylinder use on Prelude! (racerx)
the main prob right now is that the lines dont clear my golden eagle mani, even the steel braided ones need a inch or so before they can be bent....i was suggesting the civic mc and prop valve because they have 10mm fittings not one 10 and one 12 like on my lude. The guy i know who runs a earls shop says 12mm brake fitting are almost impossible to find aftermarket... yes the civic mc is considerably smaller.
Old Mar 24, 2004 | 07:23 PM
Going with a smaller mc bore will increase line pressure, BUT it will also increase pedal throw. This is not the route I would take. I would also not use a braided line in the place of a hard line. It just becomes another part you have to replace.
Like I said, get some hard 3/16" brake line, a flairing kit, and scavenge the old fittings to make your own brake lines. You can also get the fittings by ordering the brake lines from Honda. This is the only way I'd do it and to me its the only right way to do it.
Old Mar 24, 2004 | 10:31 PM
killa_lude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerx &raquo;</TD></TR><TR><TD CLASS="quote">Going with a smaller mc bore will increase line pressure, BUT it will also increase pedal throw. This is not the route I would take. I would also not use a braided line in the place of a hard line. It just becomes another part you have to replace.
Like I said, get some hard 3/16" brake line, a flairing kit, and scavenge the old fittings to make your own brake lines. You can also get the fittings by ordering the brake lines from Honda. This is the only way I'd do it and to me its the only right way to do it.</TD></TR></TABLE>
this is all good, but the problem is that i cant bend the lines steep enough off of the mc....i have 1 inch clearence.
Old Mar 24, 2004 | 10:35 PM
H22A EG6's Avatar
i got a lude mc if ya need one
pm me wit offer
Old Mar 25, 2004 | 07:33 AM
killa_lude's Avatar
Default Re: Civic Proportioning valve and master cylinder use on Prelude! (H22A EG6)
i need a prelude S proportioning valve....
j3wman
Jun 27, 2012 03:16 PM
civicexowner
Jun 18, 2009 03:07 PM
dohcem1
May 6, 2008 08:50 AM
eskerley
Jan 23, 2008 03:24 PM
