greddy TT
Old Mar 23, 2004 | 11:36 AM
homesauce's Avatar
Default greddy TT
Someone who has installed a greddy turbo timer on a 4th gen lude, can u please explain to me how to do it? (which wire goes where, etc and please be specific.) TIA
Old Mar 23, 2004 | 11:45 AM
PrecisionH23a's Avatar
Default Re: greddy TT (homesauce)
http://www.greddy.com/tech.asp
Follow the directions, very straight forward. I believe you use the standard ignition.... can someone back me up on this?
One thing you have to watch for is that the coolant fan kicks on when the turbo timer is working. If you run 2 wires backwards it will cause the fans to not kick in when the turbo timer is counting down.
https://honda-tech.com/zerothread?id=333971
Old Mar 23, 2004 | 11:59 AM
homesauce's Avatar
Default Re: greddy TT (PrecisionH23a)
Off subject but, Any oil in the charge pipe means a blown seal right? I think I've finally found my problem of not holding any boost. goddamnit
Old Mar 23, 2004 | 12:09 PM
A thin film of oil is ok, an abundance is bad.
You might want to remove the downpipe and inspect for oil as well.
Old Mar 23, 2004 | 12:16 PM
homesauce's Avatar
Yea, I'll be checking the dp asap. Would blown turbo seals cause no boost?
Old Mar 23, 2004 | 12:25 PM
If your seals are gone you will most likely be consuming a lot of oil and burning it when under load. If the seals are slowly going bad, you will still be able to create boost. If you cannot create any boost, you have a leak in your intercooler piping most likely. Check all of your vacuum lines as well.
dwashy21
Jan 22, 2014 11:13 AM
Jcards26
Mar 14, 2008 12:56 PM
WCI
Feb 9, 2004 09:12 PM
bey
Oct 27, 2002 08:49 PM
