Once again ZC STARTING PROBLEMS
Ok update. This is the post from before but diffrent. Now the car cranks but it will not start. When I put the key to the accessory position(the position where the check lights come on, and your able to open close your sunroof) there is no power to the car. When I crank it there is power and the check lights come on and I can open the sunroof but as soon as I stop holding the key like I'm trying to get it to turn over the power goes away. I think this has a something to do with why my car wont start but I checked every fuse in the car and every fuse in the engine bay and there are no blown fuses. I dont understand what is up with that. But over to the car not starting besides that I haver no idea because I checked the fuel at the injectors(I pulled them out of the motor and turned the key over. Gas came out), I checked the spark. I have both. I dont know what is wrong with my car. Help!
exactly it. i figured out that my problem was in the ignition. when you move it to the third click the check lights should come on but they dont. but if you hold it a little in front of the third click, not on the start position but close the check lights come on. i think i need to go to honda and get a new ignition.
TeamRiskEG6
29
Aug 7, 2008 05:53 AM
SiRkid
Oct 20, 2005 08:56 PM
Punker1234
Sep 20, 2005 07:02 PM
