oil leak?
Old Mar 23, 2004 | 11:26 AM
DI9ITAL's Avatar
Default oil leak?
i always have oil comin outa this area. what is the problem?
Old Mar 23, 2004 | 11:32 AM
timmy8151's Avatar
Default Re: oil leak? (DI9ITAL)
Cam Seal leak. Its a common problem with B-series engines. Just replace the old one with a newer designed OEM one or and aftermarket (ST or GE) one.
Old Mar 23, 2004 | 11:38 AM
98R-1144's Avatar
Default Re: oil leak? (timmy8151)
are the cam seals hard to replace? like need to remove the cams? or it can be swapped once the valve cover is off?
Old Mar 23, 2004 | 11:43 AM
penney's Avatar
Default Re: oil leak? (98R-1144)
yep mine is doing the same thing, still a little uncertain about how to change them, i guess i should consult the helms
Old Mar 23, 2004 | 11:44 AM
SuzukaBlueAP2's Avatar
I've never had mine leak, but, why does that leak look so much lower than the seal ? Or does the oil just come out of the bottom of the seal and therefore it looks like it is leaking lower than it actually is ?
Just curious....
Old Mar 23, 2004 | 11:56 AM
timmy8151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98R-1144 &raquo;</TD></TR><TR><TD CLASS="quote">are the cam seals hard to replace? like need to remove the cams? or it can be swapped once the valve cover is off?</TD></TR></TABLE>
It's really easy to do. Just pop off the valve cover and change the seal. You don't need to remove the cams. However, if you have a VTEC engine you need to remove the exhaust side cam plate.
While your at it change your valve cover gasket and spark plug seals. Also, you need to use some Hondabond/Permatex Grey on the cover and the seal.
Old Mar 23, 2004 | 12:04 PM
JimBlake's Avatar
Mine leaked from the VTEC valve gasket, where it's bolted against the head. It was hidden behind the valve, & collected on that little tab of the headgasket. I'm pretty certain mine didn't leak from the cam seal, but I didn't know that until it was apart.
Check it out...
https://honda-tech.com/zerothread?id=799764
To change the cam seal, you'll have to take off that plate over top of all the cam caps, then take off the last cam cap on the back end of the exhaust cam.
Old Mar 23, 2004 | 12:05 PM
DI9ITAL's Avatar
Default Re: oil leak? (ScreaminTeg)
yeah jim blake, i think im leakin from there too
Old Mar 23, 2004 | 12:51 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I replaced my old original rubber cam seal w/ the new redesigned OEM one (plastic w/ o-rings) about 30K miles ago, zero leaks since then. The newer OEM seal is only about $5.
Old Mar 30, 2004 | 04:57 PM
IVI's Avatar
IVI
Default Re: oil leak? (PatrickGSR94)
does anyone have a how-to on how to change that seal? and all the seals for that matter? what seals and gaskets should you buy?
where do you put the hondabond? more pics please.
Old Mar 30, 2004 | 06:08 PM
JimBlake's Avatar
Default Re: oil leak? (IVI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">does anyone have a how-to on how to change that seal?</TD></TR></TABLE>Yeah, my HELM manual has a really good one.
Look here:
Read MY posts - I said which gaskets I replaced. Just unbolt the components (vtec valve, solenoid, etc.) Carefully remove the old gaskets; a couple of mine tore when I took them off. (Don't scratch the aluminum surfaces - d'oh!) Put the new gaskets on & bolt the stuff back up. It's really that simple.
The only hard one is the cam plug. You have to remove the last cam cap, part of which sticks outside of the valve cover. You use a little bit of HondaBond (grey permatex) where that thing bolts down to the head itself. You'll see it when you take it off.
Old Mar 30, 2004 | 07:36 PM
zilverz's Avatar
My cam seal leaked too. B18B. the Covering end plate was a biotch to get off. It is suppose to have sealant on the bottom of it so its extra hard. But replaced mine with a $25 STR Metal cam seal. 2 big dual orings.. and i put hondabond HT on it and then reseated the cap
fatdad
Dec 20, 2008 07:30 PM
itzyaboyzeem03
Nov 2, 2008 01:47 AM
2.0L Beater
Oct 30, 2007 09:16 AM
DriveSlowHomie
Sep 22, 2004 03:50 AM
fcuked
Feb 27, 2002 06:34 PM
