$1000 for manifold and downping........
a good price for a t3 turbo manifold[ header]with the down pipe and intake manifold[to turbo] piping a good price? thanxx in advance guys/girls!!!!!
unless its all 100% stainless, w/ 3" NAME BRAND downpipe......id say u might as well just bend over and take it.........u can probably do alot better........specially ur not gonna need the pipe from the turbo to the IM....(assuming ur smart enough to run a FMIC).........
actually that is a good price for some of the good manifolds i've seen...they go up to about 1400 for some of the true equal length manifolds and that doesn't include the downpipe...just make sure that the downpipe is a solid 3" (or more depending on your turbo) and make sure that whoever is making it is using stainless steel...good luck
btw that manifold is called turbo/exhaust manifold, the only intake manifold is for your head.
pretty price but i can believe that, equal length, SS polished, custom collector, wastegate port merge, all gasket and fitting, cnc, enlarged pipe for the cat(if needed), o2 sensor port
please post your source if you dont mind us to look at it.
if it's a log style manfold=no
sohczcturbo
Sep 11, 2007 09:51 PM
godrifttoday
Sep 15, 2004 10:11 PM
