Skunk2 IM on a LS
Old Mar 23, 2004 | 10:41 AM
dAng! Kris's Avatar
Default Skunk2 IM on a LS
Will i need a different throttle cable or anything like that if i get a skunk2 IM for my ls?? TIA
Old Mar 23, 2004 | 10:47 AM
[HrZn]4life's Avatar
Default Re: Skunk2 IM on a LS (Frozty)
i would like to know this too. How much did you get your manifold for if you don't mind me asking...
Old Mar 23, 2004 | 10:50 AM
dAng! Kris's Avatar
Default Re: Skunk2 IM on a LS ([HrZn]4life)
don't got one yet, thats why im asking questions first
Old Mar 23, 2004 | 11:01 AM
zilverz's Avatar
You can use the same throttle cable .. but you will need to bend the mounting bracket
edit:
also i forgot you will need to open the holes up a little bigger in the mounting bracket to line the bolts up
No big deal its really easy to do both of those steps ..
Old Mar 23, 2004 | 11:05 AM
foxfai's Avatar
Default Re: Skunk2 IM on a LS (zilverz)
i got mine used for $150, it's been sitting in my garage for the past few months cause it's hard to put in myself. And i don't have all the instructions to put it in yet....
Old Mar 23, 2004 | 12:12 PM
LsNer00's Avatar
Default Re: Skunk2 IM on a LS (foxfai)
i found one for 288 shipped brand new but i dont know if it comes with the gasket
<the one who Frozty asked the question for
Old Mar 23, 2004 | 12:57 PM
No's Avatar
No
what kinda gain do you think you would get would this?Would you get benefits from this for having aftermarket cams?
Old Mar 23, 2004 | 01:05 PM
LsNer00's Avatar
Default Re: (narib2oo1)
supposed to be 5-8hp without cams then up to 15+ with skunk2 stage 1 cams
Old Mar 23, 2004 | 05:42 PM
whtteg's Avatar
Default Re: (LsNer00)
Does skunk2 make nonvtec cams?
Old Mar 23, 2004 | 05:52 PM
No's Avatar
No
ya i was gonna run 404's so prolly another 10 hp or so.Sounds good too me.
Old Mar 23, 2004 | 05:56 PM
Kendall's Avatar
Default Re: Skunk2 IM on a LS (LsNer00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsNer00 &raquo;</TD></TR><TR><TD CLASS="quote">i found one for 288 shipped brand new but i dont know if it comes with the gasket</TD></TR></TABLE>
Then use this opportunity to upgrade to a Hondata gasket or another insulating gasket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsNer00 &raquo;</TD></TR><TR><TD CLASS="quote">supposed to be 5-8hp without cams then up to 15+ with skunk2 stage 1 cams</TD></TR></TABLE>
That's a manufacturer's claim, so don't expect half of the power they say is possible. These claims are usually made when comparing stock components to their own components on engines built specifically for their own product testing, and tuned to make sure their products make the most power possible over stock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whtteg &raquo;</TD></TR><TR><TD CLASS="quote">Does skunk2 make nonvtec cams?</TD></TR></TABLE>
Not presently.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by narib2oo1 &raquo;</TD></TR><TR><TD CLASS="quote">ya i was gonna run 404's so prolly another 10 hp or so.Sounds good too me.</TD></TR></TABLE>
Don't try and run 404's without raising the compression by a significant margin. Hell, I wouldn't even run 402's without at least PR3 pistons.
Old Mar 23, 2004 | 06:31 PM
No's Avatar
No
i know quite a few peeps including styleteg who run 404's and stock bottom end.I was gonna do the same.
Old Mar 23, 2004 | 06:33 PM
whtteg's Avatar
Default Re: Skunk2 IM on a LS (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">
Don't try and run 404's without raising the compression by a significant margin. Hell, I wouldn't even run 402's without at least PR3 pistons.</TD></TR></TABLE>
Yea your dynamic compression ratio will go to crap with the 404's
Old Mar 23, 2004 | 06:35 PM
whtteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by narib2oo1 &raquo;</TD></TR><TR><TD CLASS="quote">i know quite a few peeps including styleteg who run 404's and stock bottom end.I was gonna do the same.</TD></TR></TABLE>
I ran my 404's that way for a short period of time until I took them out until I get some valve springs. The power increase was nice but with a higher c/r it would be alot better.
ganjasnack
May 31, 2009 02:41 PM
BG-Teg
Jul 9, 2007 09:52 PM
straggs42d15
Apr 19, 2006 12:21 PM
metal-x
May 22, 2003 12:31 PM
RolioPolio
Mar 28, 2002 02:22 PM
