is higher compression better for all motor?
Old Mar 23, 2004 | 10:40 AM
civicracer1993's Avatar
Default is higher compression better for all motor?
i was messing around with a compression calculator and ive found that a d16z6 head with a y8 gasket on a 90 DX block will give alot more compression than that same setup on a 1.6L a6 block.. is this going to be a faster setup than using the a 6 block even though that is a 1.6L ? im am a lil confused about this .. can someone explain which is faster and the main diff?
Old Mar 23, 2004 | 02:23 PM
Ryan C's Avatar
Default Re: is higher compression better for all motor? (civicracer1993)
yes generaly higher CR's will result in HP gains, you need to conider clearences before slappin together any combos
Old Mar 23, 2004 | 02:59 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicracer1993 &raquo;</TD></TR><TR><TD CLASS="quote">i was messing around with a compression calculator and ive found that a d16z6 head with a y8 gasket on a 90 DX block will give alot more compression than that same setup on a 1.6L a6 block.. is this going to be a faster setup than using the a 6 block even though that is a 1.6L ? im am a lil confused about this .. can someone explain which is faster and the main diff?</TD></TR></TABLE>
d15b2 block, d15b2 pistons, z6 head, y8 3-layer HG = 10.1:1 CR
d16a6 block, d16a6 pistons, z6 head, y8 3-layer HG = 9.95:1 CR
i would not consider this "alot" more compression...not worth swapping motors.
if your worried about compression...
d16a6 block, d16a6 pistons, z6 head, y8 2-layer HG = 10.23:1 CR
you bring up an interesting point though... heres a better way to put it...
which would be a faster setup (for drag racing i assume) with the following the same:
tranny
intake
exhaust
cam
car
a d16 with 10:1 static CR or a d15 with 10:1 static CR? more torque with the long stroke d16 or possibly more high end hp and engine acceleration with the better R/S ratio of the d15?
Old Mar 23, 2004 | 04:39 PM
Ryan C's Avatar
Default Re: is higher compression better for all motor? (fastcrxsi90)
i'm not an SOHC fan but i'd take the 1.6
Old Mar 23, 2004 | 06:25 PM
LudeyKrus's Avatar
What's the redline and powerband like on both motors?
Assuming they both have the same redline, the 1.6liter will have more displacement, therefore more power and a fatter powerband, if only by a little bit.
JDMblkguy
Apr 11, 2009 06:51 PM
DeadVet
Apr 26, 2005 11:51 AM
DeadVet
Mar 30, 2005 04:37 PM
onemanlan
May 24, 2004 06:50 PM
