roller rockers?
Old Oct 22, 2001 | 07:56 AM
carolinaACCORD's Avatar
Default roller rockers?
has anyone used or does anyone know how good the ferrea roller rockers and cams
perform, and also if they are of good quality?
Old Oct 22, 2001 | 08:07 AM
Spade's Avatar
Default Re: roller rockers? (HONDApowerEXTREME)
I heard that you can't use VTEC if you get them.
My HX has roller rockers on the exhaust end.....stock
Old Oct 22, 2001 | 08:42 AM
rioninja's Avatar
Default Re: roller rockers? (Spade)
Its not that you cant use vtec, but i have hear that using cams with too radical a lift will cause them to get -stuck- on the high lobe. I think it has something to do with the pins not having enought time to disengage or something.
*only what i have heard*
Old Oct 22, 2001 | 09:05 AM
3rdShift.org's Avatar
New User
Default Re: roller rockers? (RioNinja)
I don't have the picture handy, but I believe by design the VTEC lobe does not interact whatsoever when using the ferrera roller rockers. I personally don't see any HUGE advantage as there are plenty 500+ hp motors out there using honda valvetrain.
Old Oct 22, 2001 | 09:37 AM
Daemione's Avatar
Default Re: roller rockers? (3rdShift.org)
Again, just what I've heard, but I believe they're not commonly used in Hondas because they're not all that reliable at high-rpms (7,000+).
But from the accounts I've read, they reduce valvetrain losses significantly (hence their use in the HX civics - low-revving, high fuel efficiency).
[Modified by Daemione, 1:37 PM 10/22/2001]
Old Oct 23, 2001 | 11:07 PM
ultraspeed2nr619's Avatar
New User
Default Re: roller rockers? (Daemione)
i just asked the same question to ferrea thenselves at the races in palmdale.. and they actually told me that they dont even have camshafts built for it yet so noone is running them.. but i knoe the OTDA ones are similar.. it rids the VTEC function...but is *****-tah-*** fast...a b18c ran around 11 with them...the VTEC KILLER camshafts from TODA....??>>!!
92integra_ls
Aug 28, 2010 06:28 AM
94civicdeleon
Jun 20, 2009 02:48 PM
GSRCRXsi
Oct 24, 2006 03:03 PM
boosted94cx
Mar 25, 2006 04:20 PM
GreyRS
Dec 27, 2001 01:48 AM
