Bad ass truck.. vid inside
This is one bad *** ****.
Right click and save as. or you can click the link to stream it
http://www.bandagbullet.com/ba...t.WMV
Info on the truck
Make and Model
Kenworth T400
Engine
Two V8 92-Series Detroit Diesel engines fitted with two blowers, four turbo chargers and injected with nitrous oxide. The original 75mm injectors have been increased to 260mm. Pistons, conrods, crankshaft and camshaft have been balanced. Cylinder heads and air boxes have been ported and polished.
Capacity
24 litres (1500 cubic inches)
Horsepower
2200hp @ 3000rpm - 2800hp nitrous oxide boost
Torque
5600 ft/lb
Transmission
Aliison Auto-manual shift - CR 6000
Rear Axle
Eaton 2300-series with Detroit no spin locker
Rear Suspension
Ladder bar with Watts link assembly
Info on the truck
Make and Model
Kenworth T400
Engine
Capacity
Horsepower
Torque
5600 ft/lb
Transmission
Rear Axle
Rear Suspension
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle »</TD></TR><TR><TD CLASS="quote">This is one bad *** ****.
<FONT SIZE="2">Engine
B16a 92-95 SiRII series Japanese unleaded engine fitted with two ebay Tornados, four Interfoolers, and injected with fuel injector cleaner. The original 75mm injectors have been increased to 260mm. CTR pistons, conrods, crankshaft and camshaft have been balanced. Cylinder heads and air boxes have been ported and polished.
Capacity
1.6 litres (16 cubic inches)
Horsepower
Torque
99 ft/lb</FONT>
Transmission
Rear Axle
Rear Suspension
Ladder bar with Watts link assembly</TD></TR></TABLE>
Whoa! No ****?!
Capacity
Horsepower
Torque
99 ft/lb</FONT>
Transmission
Rear Axle
Rear Suspension
Whoa! No ****?!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodrez »</TD></TR><TR><TD CLASS="quote">
Whoa! No ****?!
Damn how long did that take you to write HA
Whoa! No ****?!
</TD></TR></TABLE>Damn how long did that take you to write HA
