dizzy conversion obd0 to obd1??
Old Mar 22, 2004 | 09:48 PM
seerxsi's Avatar
Default dizzy conversion obd0 to obd1??
i just need help to somehow.. get my jdm b16 obd0 distributor to run... obd1 i appreciate the help
Old Mar 22, 2004 | 10:04 PM
StorminMatt's Avatar
Default Re: dizzy conversion obd0 to obd1?? (seerxsi)
I don't know that you can actually gut a pre-1992 distributer and use 1992+ parts in that body to make it work with a 1992+ ECU. As far as I know, you have to use the complete 1992+ distributer.
Old Mar 24, 2004 | 05:32 PM
seerxsi's Avatar
havent been online for a while...but yeah there is a way to do it...but was areasonable price for someone to do it....please dont post if your not sure
thanks
Old Mar 24, 2004 | 05:33 PM
seerxsi's Avatar
*but what is a reasonable
Old Mar 24, 2004 | 06:11 PM
Blown90hatcH's Avatar
Default Re: (seerxsi)
You can not run the OBD1 distributor on an OBD0 ecu.
With this you can Run It
Old Mar 24, 2004 | 09:10 PM
Qfactor's Avatar
Default Re: (Blown90hatcH)
yes you can I've already tried and ran an OBD1 dizzy with a OBD0 ecu and works fine, but you can't run and OBD1 ecu with OBD0 dizzy I got CEL (4).
Old Mar 24, 2004 | 10:12 PM
To Muckin Fuch's Avatar
Default Re: (Qfactor)
Hey Ive got a OBD-1 dizzy, ill trade you straight up for the non-OBD dizzy if your interested
Old Mar 24, 2004 | 11:25 PM
Fobtions's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Qfactor &raquo;</TD></TR><TR><TD CLASS="quote">yes you can I've already tried and ran an OBD1 dizzy with a OBD0 ecu and works fine, but you can't run and OBD1 ecu with OBD0 dizzy I got CEL (4).</TD></TR></TABLE>
this is not true.
Old Mar 25, 2004 | 01:50 AM
projektCRX's Avatar
Default Re: (Fobtions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">
this is not true. </TD></TR></TABLE>
i second that. i swapped a b18b1 OBD1 in my crx. tried to splice the OBD1 dizzy that came with the motor, but no, it was click but it would not fully turn over. till i realized. you CANT do that, so i picked up a OBD0 91 ls dizzy to match wit my ECU (91 ls). ... started like a champ.. hope that helped...
Old Mar 25, 2004 | 02:45 PM
seerxsi's Avatar
yes i am interested in trading your obd1 dizzy let me know my email is nchl74@aol.com
btw i already have a wiring harness conversion, i was just trying to see if i can convert the obdo dizzy to obd1 since it did come out from the sir crx (obd0)
Old Mar 25, 2004 | 02:53 PM
RobbieG35's Avatar
12 Years Strong
I wired an OBD1 dizzy to my OBD0 B16 swap trying to get rid of code 4, it worked but I still had a damn code 4
Old Mar 25, 2004 | 06:32 PM
Qfactor's Avatar
Default Re: (projektCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projektCRX &raquo;</TD></TR><TR><TD CLASS="quote">
i second that. i swapped a b18b1 OBD1 in my crx. tried to splice the OBD1 dizzy that came with the motor, but no, it was click but it would not fully turn over. till i realized. you CANT do that, so i picked up a OBD0 91 ls dizzy to match wit my ECU (91 ls). ... started like a champ.. hope that helped...</TD></TR></TABLE>
no $hit that's what I said. I've tried both combinations and the only that works is
OBD1 dizzy running with OBD0 ecu, some people just jump to conclusion when they have NOT actualy spent the time to do this.
Old Mar 26, 2004 | 11:46 AM
seerxsi's Avatar
well i have the wiring harness conversion (obd0 to obd1) and i have the p28 ecu with a mugen chip the only thing im asking is IF i can some how use my obd0 jdm b16 dizzy and convert it to obd1 somehow...i know this can be done bc they were charging me $50 but i think thats 2 high....or is it reasonable??
anyone know a site of some sort to do this on your own
thanks alot for the help!!
Old Mar 26, 2004 | 06:37 PM
Qfactor's Avatar
the engine will run but with CEL code (4). but you should get the OBD1 dizzy.
88EDHatch
Nov 12, 2010 11:27 AM
dougshatch
Jun 14, 2007 12:41 PM
ludesrv
May 12, 2007 08:58 PM
kingkong
May 9, 2005 11:19 PM
