Turbo timer, alarm, remote start conflict
I just installed a turbo timer on my car,
it works fine, however I cant turn my alarm on as its counting down. SO i end up sitting in my car anyways waiting. Any suggestions? I have remote start too.
And what position/ wire color on a p28 (92-95 civic ex, d16z) is the vehicle speed wire? I need to hook up the turbo timer to it so I can use the auto countdown.
ok all you have to do is disconnect the ingiton wire comming off your alarm and connect it to you accessory wire and youll be in able to arm your car while your turbo timer is running you just have to make sure your turbo timer isnt hooked into your accssory wire if it is youll want to disconnect it, it would just make your radio and heat run while your turbo timer is running
