b16a crx, vtec works but only untill 7500rpms, sorry.
Old Mar 22, 2004 | 08:42 PM
TecHnOCal's Avatar
Default b16a crx, vtec works but only untill 7500rpms, sorry.
edit* get off my name bitch
Old Mar 22, 2004 | 09:15 PM
^jefs0ng's Avatar
Banned
What? Vtec STOPS at 7500 or you can't go past 7500 period? change your oil?
Old Mar 22, 2004 | 09:59 PM
ScottEK's Avatar
Default Re: (^jefs0ng)
Your problem is you have an OBD-0 PR3 Automatic ECU.
Old Mar 23, 2004 | 03:17 AM
japspecjohn's Avatar
Default Re: (beta13)
how do you tell the difference between the 2 on the out side?
Old Mar 23, 2004 | 04:17 AM
beavis's Avatar
Default Re: b16a crx, vtec works but only untill 7500rpms, sorry. (TecHnOCal)
vtec with stock rev limiter stops at 7500 get a higher rev limiter
Old Mar 23, 2004 | 04:24 AM
ScottEK's Avatar
Default Re: (japspecjohn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japspecjohn &raquo;</TD></TR><TR><TD CLASS="quote">how do you tell the difference between the 2 on the out side?</TD></TR></TABLE>
By the serial number.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZCed89hatch &raquo;</TD></TR><TR><TD CLASS="quote">vtec with stock rev limiter stops at 7500 get a higher rev limiter</TD></TR></TABLE>
Umm no? He could convert it to manual though.
Modified by beta13 at 11:51 PM 3/23/2004
Old Mar 23, 2004 | 06:59 AM
Whats different about the serial number of an automatic?
Old Mar 23, 2004 | 11:04 AM
ScottEK's Avatar
You can tell by the letters in it, some where there is a picture floating around that shows the part of the serial number and lists all the different letters it could be and whether they are manual or automatic.
Old Mar 23, 2004 | 12:12 PM
ScottEK's Avatar
Ok here's your answer, grab your ECU and look at the last 3 numbers/letters in the serial number. Now compare to this list:
in 88-91 ecus (PM6, PR4, PW0, PR3, PM7):
5spd = 000, 001, 002, A00, A01, A10, J00, J001, C01, C00
Auto = J51, J50, A50, A51, 901, A60, C50, C51, X30, A80
I had the same problem a long time ago and I was able to find the post. There is a way to modify the ECU into being a manual ECU with the 8220 rev limit, it involves moving a resisitor. I did it, it was very hard since the resisitor is a surface mount piece so it's very tiny but it did fix my rev limit.
95lscivic
14
Apr 30, 2007 10:01 AM
sazdasl
Dec 17, 2006 09:00 PM
vtecriver
Oct 30, 2006 01:46 AM
vtec_crazy
Feb 9, 2005 01:30 PM
Mefain
Jul 6, 2004 08:37 PM
