93 LS B18 IN A 89 CRX SI.....
ok... i got my swap... a COMPLETEEE b18 out of a 93 ls the other day. what am i going to need to do to get this to drop right in??? i already have motor mounts.. what will i need to change up???
I put the same exact motor in my car. U have to get a90-91 ECU, and its best to get it chipped. Oh and as for the wiring u can use your stock Si engine harness and injectors, but u have to get a distributor from a 90-91 integra, and u have to modify like 3 plugs and extend the O2 sensor. Its real easy to do. And dont forget to dent in the body where the alternator is at. And thats pretty much it. Real easy to do.
I never had to modify any plugs when I swapped an LS in a crx. It was a 93 LS in an 88 rex. I used 90-91 axles, distributor, injectors, and ecu, the stock wiring harness from the rex. Everything went right together using hasport mounts and linkage.
mrtony86
20
May 25, 2006 06:03 AM
pappaj
May 5, 2006 06:13 PM
CRX_GUY_123
14
Apr 13, 2004 06:39 PM
CRX_GUY_123
Mar 23, 2004 08:22 PM
