RSX oil filters
Old Mar 22, 2004 | 05:36 PM
Sliced Beard's Avatar
Default RSX oil filters
does anybody use RSX oil filters on their b series
i have heard that using one will raise oil pressure
can someone please shed some light on the subject
Old Mar 22, 2004 | 06:14 PM
onePOINTsix's Avatar
Default Re: RSX oil filters (dirtyd463)
yeah it will increse oil pressure, good for VTEC motors but it dosent matter on anything else
Old Mar 22, 2004 | 08:14 PM
Default Re: RSX oil filters (Sideout)
oh
well i am running a LS and am planning to stay LS so i guess it is useless to me
do you think it would still be good to maybe prevent oil starvation or maybe alleviate the problem(i know a baffled oil pan is good for that) but increasing the oil pressure help out on lubrication if installed with an oil cooler
Old Mar 22, 2004 | 09:18 PM
BluLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideout &raquo;</TD></TR><TR><TD CLASS="quote">yeah it will increse oil pressure, good for VTEC motors but it dosent matter on anything else</TD></TR></TABLE>
can you explain why?
Old Mar 22, 2004 | 10:34 PM
TheGSRGuy's Avatar
Default Re: RSX oil filters (BluLude)
Honda recently switched to smaller filters on all their engines (probably except the NSX, which has its own unique filter).
So if you go to the dealer now, they use the 'RSX' filters on all the cars.
Old Mar 23, 2004 | 09:20 AM
BluLude's Avatar
Default Re: RSX oil filters (TheGSRGuy)
All as in smaller filters even in non K series? Also why do they do it though, how does putting in a smaller oil filter increase oil pressure?
Old Mar 23, 2004 | 09:29 AM
MightyMouseTech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BluLude &raquo;</TD></TR><TR><TD CLASS="quote">All as in smaller filters even in non K series? Also why do they do it though, how does putting in a smaller oil filter increase oil pressure?</TD></TR></TABLE>
They don't increase oil pressure, this is how stupid internet rumors get started. Some people just don't have a clue. Have these people actully cut open both filters and compared them?
The smaller filters actually have a LARGER filter media than the old PT7's, (I HAVE cut them open) so they would actually make a smaller difference on the pressure than the old ones. Although, I am not sure how a filter would make any difference on the pressure , that is what the oil pressure relief valve does in the oil pump.
And the reason why Honda now uses a smaller filter is simply faster oil pressure spool up on start up. If it takes 1/2 sec less to fill and pressurise the oil system, that is 1/2 second less of engine bearing wear.
Old Mar 23, 2004 | 09:45 AM
Rtype16's Avatar
Default Re: RSX oil filters (MightyMouseTech)
Woohoo Mighty mouse knows what he is talking about. Yes Honda has discontinued the old filter and have now switched all Hondas to the newer smaller filter. They do not increase oil pressure.
Old Mar 23, 2004 | 09:59 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MightyMouseTech &raquo;</TD></TR><TR><TD CLASS="quote">The smaller filters actually have a LARGER filter media than the old PT7's, (I HAVE cut them open)...</TD></TR></TABLE>The PT7 is the Canadian Fram ones. Have you cut open the P0H ones(Filtech)?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MightyMouseTech &raquo;</TD></TR><TR><TD CLASS="quote">Although, I am not sure how a filter would make any difference on the pressure , that is what the oil pressure relief valve does in the oil pump.</TD></TR></TABLE>Different pressure DROP thru the filter. But probably not enough difference to matter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MightyMouseTech &raquo;</TD></TR><TR><TD CLASS="quote">And the reason why Honda now uses a smaller filter is simply faster oil pressure spool up on start up. If it takes 1/2 sec less to fill and pressurise the oil system, that is 1/2 second less of engine bearing wear.</TD></TR></TABLE>What about clearance? It looks like there isn't enough room for the bigger filter on our '03 Accord K24. So some cars NEED the smaller size, but Honda probably doesn't want to inventory several different kinds.
Old Mar 23, 2004 | 10:17 AM
Default Re: RSX oil filters (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">The PT7 is the Canadian Fram ones. Have you cut open the P0H ones(Filtech)?</TD></TR></TABLE>
I have about 12 different filters sitting around the shop all cut open. I now use the PLM small filter on all my cars. (well, the Hondas at least )
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Different pressure DROP thru the filter. But probably not enough difference to matter.</TD></TR></TABLE>
The filter media and surface area determine the pressure drop, not the size of the can. Another reason why I use the PLM's, they have a larger filter area.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">What about clearance? It looks like there isn't enough room for the bigger filter on our '03 Accord K24. So some cars NEED the smaller size, but Honda probably doesn't want to inventory several different kinds.
You can easily put a large filter on the K series motors (Accord, Civic, CRV, Element, TSX..) (is there anything that DOESN'T use a K series...sheesh). A hell of a lot easier than trying to change the damn filter on a Prelude SH. (that engineer should be shot and shoved inside a crankcase)
Old Mar 23, 2004 | 10:40 AM
TheGSRGuy's Avatar
I am very tired of companies using creative marketing to convince people that smaller filters give better oil pressure...it just isn't true.
Old Mar 23, 2004 | 11:23 AM
thanks for clearing that up all, did not know
Old Mar 23, 2004 | 11:29 AM
oh and on vtec motors you need more oil pressure then a non vtec engine because vtec is activated with oil pressure
Old Mar 23, 2004 | 04:15 PM
Gsr_Hybrid_theory's Avatar
i work for acura,and ALL oil filters, execpt the nsx and i believe the 2.5tl, vigor,legend.. (from what i remember at least) is now the smaller filter, fits on cl's tl's mdx's and all integras, as well as rl's... (the small filter was intro'd first on the rsx then the 03 mdx now on the tsx, new tl and well the rsx of course
Old Mar 23, 2004 | 04:52 PM
dfoxengr's Avatar
ive run them for about 1.5 years now, no probs at all. no gauge yet though, just ordered it.
Old Mar 23, 2004 | 04:56 PM
TheGSRGuy's Avatar
Default Re: RSX oil filters (hybridvteceg)
When in doubt...go with OEM.
Old Mar 23, 2004 | 05:12 PM
now see
this is why i created this thread
i was uninformed and wanted clarification
guess what i got....thats right clarification
this is why we call this site Honda-<U>TECH</U>
Old Mar 24, 2004 | 03:36 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">ive run them for about 1.5 years now, no probs at all. no gauge yet though, just ordered it.</TD></TR></TABLE>I used Fram filters for 25 years without any problems... That doesn't mean I don't believe about the cardboard end caps & smaller filter media. When I learned about that stuff I switched. When Fram builds the PLM filters for Honda, I hope they make them better than that.
nevaeh_bebe
Mar 25, 2008 05:09 PM
Cashflo
15
Sep 5, 2006 02:22 PM
slammedc2x
Mar 16, 2005 07:39 PM
vtec.dc2
Mar 9, 2004 04:41 AM
infamousALLMTR
Jun 3, 2002 07:35 PM
