b16 head on a b18 block
Old Mar 22, 2004 | 05:19 PM
cincispeedemon's Avatar
Default b16 head on a b18 block
I'm no where near a Honda mechanic, so bear with me.
If I out a b16 head on my b18 block, that would be similar to an ITR motor, correct? Keep in mind it's a b18a1.
If I did this,
#1 would it be worth it?(hp wise)
#2 would it be worth while to set this head up for F/I ?
#3 Would I need a b16 ecu, or b18 ecu for the vtec?
Old Mar 22, 2004 | 05:21 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: b16 head on a b18 block (cincispeedemon)
A ported B16 head = ITR head
You'll have more compression with a B16 head... Yeah, go for it.
Old Mar 22, 2004 | 05:54 PM
Default Re: b16 head on a b18 block (LSVTEC 91 Civic)
will it hold up when i boost it later on?
Old Mar 22, 2004 | 06:05 PM
Banned
High compression + Boost = Bad idea
If you're boosting i'd stay with the B18 head.
If you're going N/A, I'd go with the B16 head for the compression.
Old Mar 22, 2004 | 10:05 PM
honda head's Avatar
more compression with b16 head "ls-vetc rules"
Old Mar 24, 2004 | 06:41 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cincispeedemon &raquo;</TD></TR><TR><TD CLASS="quote">
If I did this,
#1=yea
#2=if you leave stock pistons compression would be still low, you shoudl be ok with a low psi turbo since not compression but internals would be the ''controlling'' factor in how much boost you can have.
#3=you would need a vtec ecu(without iabs), brought up to 1.8 lsv specs
Old Mar 24, 2004 | 07:57 AM
Banned
Ported B16 Head with CTR pistons is a great combo.
Old Apr 13, 2004 | 07:11 PM
WiLLMaTiX's Avatar
Default Re: (LSVTEC 91 Civic)
If anyone could let us know how much ABOUT that costs, and what exactly needs to be done to the block would help, what kinda head gasket to use, and what a safe redline would be before warping the crankshaft. And one more thing, if i buy a balanced crankshaft, connecting rod, piston combo which is capable of 11000 rpms, what kinda head work could i get to match that?
Old Apr 13, 2004 | 11:17 PM
B18Tahtaras's Avatar
Default Re: (1993sir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993sir &raquo;</TD></TR><TR><TD CLASS="quote">sorry guys but you all are wrong cuz the b18gsr head makes more compression on any motor with any pistons. why you ask cuz of the shape and design of the combustion chamber for the people who dont know.but yes a vtec head on a b18a block if you havent heard yet, is an lsvtec and has become quite common nowadays. and will run just as good if not better then a stock itr motor .</TD></TR></TABLE>
Sorry... but not quite correct. There is one downside to the ls vtec. The rod stroke ratio causes it to be not to reliable. Which is why the gsr comes stoch witha block girdle. To handle the High rpm with the added compression.
If you notice the rod to stroke ratio of the vtec motors is a bit shorter then that of the non vtec motors. The only way to help counter act this problem, or prolong the life of your ls/vtec is to Get two main things. (1) a Block girdle... the ones from the gsr's are PERFECT, and convert it to a Semi-closed Deck.
And there are other alternatives... if you have the crank balanced, this will help, as well as shot-peened connecting rods.
As for turboing your motor, if you want to run high boost. these are things that you are going to want to do anyway, so why not go for it. If you are going to go through this much trouble, you may as well get Eagle h-beam connecting rods, and JE low compression Forged pistons. And you will be set for a while. If you plan on a really rocking motor... that is a different story... haha
torqueMONSTER
Jul 28, 2005 05:06 PM
lastpunkinline
Apr 16, 2004 11:09 PM
kevinoneill
25
Sep 26, 2003 10:17 AM
Malice
Mar 6, 2002 07:29 PM
SiBirdie
Nov 11, 2001 08:43 AM
