AEM bypass problem after install check engine light ON!
Old Oct 21, 2001 | 10:23 PM
97 CIVIC EX's Avatar
Default AEM bypass problem after install check engine light ON!
I just install the AEM by-pass onto my car. I mounted it between the throttle body and the AEM intake pipe because I didnt wanted to cut the pipe in two. My engine light came on and my car was running very RICH on fuel. And I need to rev it to 3k for the car the move at all in 1st gear. Its giving me engine code 3 (map sensor problem) but dont know how to fix it. I had the intake for two years the light never came on, but now it came on two times. Let me know what could be the prolbem. THANKS a lot for your help!!
Old Oct 22, 2001 | 06:16 AM
Spade's Avatar
Default Re: AEM bypass problem after install check engine light ON! (97 CIVIC EX)
Maybe the thing is too close to the trottle body. do you have a CAI!?! If not then don't bother with the bypass. If so, start cutting.
Old Oct 22, 2001 | 06:18 AM
hobo79's Avatar
New User
Default Re: AEM bypass problem after install check engine light ON! (Spade)
yeah, either start cutting and place between it instead of near the throttle or reset the ecu by disconnecting the battery and that may work too. i would think that cutting the pipe and putting bypass there is better.
tooma12
Honda Civic (2006 - 2015)
11
Jun 28, 2009 12:16 AM
marshall81
17
Dec 3, 2006 05:33 PM
DrewkCarrigan
Honda S2000
Mar 12, 2006 04:46 PM
waijsR
Oct 30, 2003 01:43 AM
Merlin1o
Sep 17, 2001 04:11 PM
