? about alternator/idle
Old Mar 22, 2004 | 01:08 PM
DIE DIE's Avatar
Default ? about alternator/idle
can a loose AC belt **** up your alternator?? And can a fucked up alternator make your idle too low like it's gonna stall? I got the right size belt on there now, but the idle was still shitty, (like 400) so i adjusted the idle screw on the TB and since then the idle is fine, except now theres a loud knocking sound. WTF is going on???? Advice please. Thanks
94 JDM h22 P13 if it makes a difference. Still ruuns strong, just want to get rid of the noise. Should I change the idle back to 400 and see if the knock stops? then if it does go buy a new alternator?
Old Mar 22, 2004 | 01:30 PM
JimBlake's Avatar
Default Re: ? about alternator/idle (seecretninja)
Whatever's making the knocking noise maybe caused the low idle. But probably not related to the loose belt. Find out what's making the noise first, then go from there. Use a piece of hose for a stethoscope.
Old Mar 22, 2004 | 01:33 PM
DIE DIE's Avatar
it's coming from the left side of the valve cover, or somewhere near there.
Zigory
Honda Civic (2001 - 2005)
Apr 13, 2018 06:30 PM
JasonYo
Apr 3, 2010 10:32 AM
DIE DIE
Mar 21, 2004 12:35 PM
Benj
Feb 20, 2003 10:46 PM
mugenracer
Aug 22, 2002 11:17 AM
