"H" centercap for oem integra wheels
does any one know what honda ceter cap will fir the 94-95 GSR blades
Im trying to get H but i dont know what will fit propery-
i think the 99-00 civic Si but not sure... and i searched and found nothing
Si centercaps will NOT fit 94-95 GS-R wheels correctly. The diameter is the same and both caps will fit in the hole on both wheels, but the GS-R centercap is thicker, and the Si cap is thinner, so the Si cap sinks into the GS-R wheel, while the GS-R cap sticks out of the Si wheel. I tried the same thing once from my friend's wheels and was disappointed.
This thread was doomed from the start
So are you referrring to the 94-95 wheels or the 98-01 wheels?
The 95's are called hammer/fat fives and the 98-01 are the blades/swirlies.
To answer the question I think you asked
98-01 gsr wheels(blades) can use the "H" center cap from the 99-00 Civic Si.
.So are you referrring to the 94-95 wheels or the 98-01 wheels?
98-01 gsr wheels(blades) can use the "H" center cap from the 99-00 Civic Si. Trending Topics
excuse me -- i meant fat fives--
i have only heard the 94-95 as fat fives or blades and the 98-01 as swirlies..
but to clarify-- i am looking for center caps to fit my 95 GSR with stock wheels.
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">Si centercaps will NOT fit 94-95 GS-R wheels correctly. The diameter is the same and both caps will fit in the hole on both wheels, but the GS-R centercap is thicker, and the Si cap is thinner, so the Si cap sinks into the GS-R wheel, while the GS-R cap sticks out of the Si wheel. I tried the same thing once from my friend's wheels and was disappointed.
Patrick is right! I did the same thing and got the same results. I ended up buying aluminum "H" stickers from another member here which I just stuck on top of the GSR centercap. It looked OEM and I didn't have to worry about fitment.
wait so 99-00 si center caps will fit on the 98-01 stock blades??? i know hes asking for 95 gsr wheels but i would like to know about the 98-01 blades
I had blades on my EG back in the day. I used centercaps off of an old Accord I found in a junk yard, they fit well and looked great. I'm not sure as to what year the Accord was because it was over 3 years ago when I did that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juicyfn »</TD></TR><TR><TD CLASS="quote">wait so 99-00 si center caps will fit on the 98-01 stock blades??? i know hes asking for 95 gsr wheels but i would like to know about the 98-01 blades</TD></TR></TABLE>
Yes. I have 2 sets of 98+ GSR wheels and 1 set of 00 Si wheels. The center caps on those wheels are interchangeable. If you want pictures, PM me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhAtBoY Si »</TD></TR><TR><TD CLASS="quote"> I ended up buying aluminum "H" stickers from another member here which I just stuck on top of the GSR centercap. It looked OEM and I didn't have to worry about fitment. </TD></TR></TABLE>
i suggest you just try what phatboy SI did, sounds like a pretty good idea to me. if you live around the bay area/marin county, we could take the "H's" off my '00 Si rims.
B18B EK
Nov 29, 2002 11:28 PM
