Quick release steering wheel options?
Old Mar 22, 2004 | 11:52 AM
PM-Performance's Avatar
Default Quick release Steering wheel options?
I know someone who has like a Paddle type release. Its a real nice anodized finish. I cant remember where he got it from. But does anyone know of who would make something like this? I dont like the ones with the pins on each side to take it off. Something just doesnt jive with me about those
Thanks.
Old Mar 22, 2004 | 11:56 AM
Jon V's Avatar
Default Re: Quick release Steering wheel options? (itr206)
https://honda-tech.com/zerothread?id=772588
Old Mar 22, 2004 | 02:08 PM
Default Re: Quick release Steering wheel options? (Jon V)
heres what im looking for. its alot cheaper and alot of the racers use it .
I need to know what size the stock steering shaft is though so i can order this ,.
Uses a spring loaded sleeve that releases three separate lock ***** when the sleeve is squeezed against the back of the hub. No pins to mess with. Hub is tapped for three 1/4-28 bolts on a 1.75" bolt circle for the steering wheel. Hardware to attach wheel is included. The 1" hex inner member is a very close sliding fit with the hub to minimize backlash. Hub is aluminum, hex adapter is steel.
Old Mar 22, 2004 | 02:46 PM
the only shaft sizes they have to choose from is 5/8 and 3/4? will either of those fit a Honda without having to weld it on .,
Old Mar 22, 2004 | 04:27 PM
uNF$@#!'s Avatar
get a splined version.
that hex thing looks like freeplay heaven
Old Mar 22, 2004 | 04:30 PM
Default Re: Quick release Steering wheel options? (Soup ****)
i might jsut get the reg hub from Sparco then . i dont wanna weld anything in if possible
thing that sucks is ther person i got the wheel from already drilled out the 3 holes for this hub above. I might just fill them in with something to make them less noticeable
Old Mar 22, 2004 | 04:43 PM
Kengs's Avatar
Have you considered the Works Bell Rapfix? Ed (yellow blur) is using one with his sp00n wheel; it worx great
Old Mar 22, 2004 | 06:21 PM
01PYTypeR#1140's Avatar
From: Couple SW99 40 Cal. For Ya, Do Ya Really Want It.., NJ, U.S.A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">i might jsut get the reg hub from Sparco then . i dont wanna weld anything in if possible</TD></TR></TABLE>
I picked up the Sparco quick release, although it was a little on the pricey side. I've had it for a year, and I love it.
Old Mar 22, 2004 | 09:20 PM
Warren's Avatar
Wrong-Way Wang
Get a good hex one, like from LTB. It's much easier to find center, and there isn't much freeplay. The people that say there's too much freeplay have never used one. The hex ones are cheaper too. Added bonus.
You shouldn't be busting gobs of dollars on this. It's an easy mod. Momo hub adapter, quick release adapter, and a nice Momo steering wheel (mod 78) can all be had for 300 some odd dollars.
Warren
Old Mar 22, 2004 | 09:31 PM
SuperTwinz's Avatar
This one is cool:
Old Mar 22, 2004 | 09:33 PM
B2FiNiTY's Avatar
Default Re: Quick release Steering wheel options? (kengs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kengs &raquo;</TD></TR><TR><TD CLASS="quote">Have you considered the Works Bell Rapfix? Ed (yellow blur) is using one with his sp00n wheel; it worx great </TD></TR></TABLE>
word.
Old Mar 23, 2004 | 01:24 AM
00 FBP ItR's Avatar
The only problem with that one is it extends your steering 2.5" closer..
I have a pic of it w/ the measurements if anyone wants to see it.
Old Mar 23, 2004 | 03:12 AM
Default Re: Quick release Steering wheel options? (00 FBP ItR)
yea i deff dont want the wheel closer. I have a hard enuff time driving it now becuase im soo big. Now with the quick release do i still need a reg style hub? then attach the quick release to that hub?
Old Mar 23, 2004 | 03:50 AM
00 FBP ItR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">yea i deff dont want the wheel closer. I have a hard enuff time driving it now becuase im soo big. Now with the quick release do i still need a reg style hub? then attach the quick release to that hub?</TD></TR></TABLE>
Yup, Most quick releases are a 'spacer' type which basically 'sandwhiches' in between the hub/steering wheel.
Most QR's fit on to a regular momo hub... the only company i've seen that needs a 'special' hub is Tekniq, which I think is purely a marketing scheme.
Old Mar 23, 2004 | 03:53 AM
The Sparco hub is the same as MOMO though right? also do i have to worry about them disattaching while driving like people say? i didnt really thin about it until i read it on a post in here
Old Mar 23, 2004 | 06:15 AM
00 FBP ItR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">The Sparco hub is the same as MOMO though right? also do i have to worry about them disattaching while driving like people say? i didnt really thin about it until i read it on a post in here</TD></TR></TABLE>
Sparco/momo hub.. pretty much the same stuff.
None of the people I know with the quick release have has had any problems with it unlocking and disattaching while driving, splined/ball bearing lock =
Old Mar 23, 2004 | 06:17 AM
nice . well i really like your set up.
Old Mar 23, 2004 | 06:23 AM
00 FBP ItR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">nice . well i really like your set up. </TD></TR></TABLE>
Thanks.
I don't wanna turn this into a sales plug thread...
We can contact through PM's.
Old Mar 24, 2004 | 09:03 AM
sa04's Avatar
Try http://www.upgrademotoring.com/qwikrelease.htm. They are recommended for racing only, not for street use. It's a little pricier now, but it bolts right onto your existing shaft.
Although Warren has a good point about a hex hub being easier to center, i don't use a horn so it's easy to mark center.
Old Mar 24, 2004 | 09:30 AM
Big Phat R's Avatar
Here is another option from Smart Racing Products.
http://www.smartracingproducts...s.htm
Default Re: Quick release Steering wheel options? (sa04)
I got mine from FBP ITR yesterday . its funny i have the same wheel as you have picked too. lol.
Old Mar 24, 2004 | 09:42 AM
cre18's Avatar
Default Re: Quick release Steering wheel options? (01PYTypeR#1140)
my signal quick release
Old Mar 24, 2004 | 09:47 AM
heres the one i got .
Old Mar 28, 2004 | 06:52 PM
Sparco and Momo aren't the same, because mine doesn't look anything like the Momo one in that picture.
Old Mar 28, 2004 | 09:30 PM
Warren's Avatar
Wrong-Way Wang
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01PYTypeR#1140 &raquo;</TD></TR><TR><TD CLASS="quote">Sparco and Momo aren't the same, because mine doesn't look anything like the Momo one in that picture.</TD></TR></TABLE>
They're referring to the common 6 bolt pattern to attach the wheel to the hub or quick release. Looks like that QR is drilled for multiple patterns.
Warren
