oem sway bar questions
which is the best front and rear sway bars from honda? Is it the Type R? I have a 92 civic cx and i was wondering what i need to install a Integra Type R front and rear sway bar in my car? thanks
yeah the 22mm type r rear sway is the best you can get, as for the front iam really not sure. you will need gsr lower control arms mounting brackest for the sway bar and some other stuff look it up on hybrid honda arcived articles.
I have seen the GS-R/Type-R front swaybar (24mm) installed on a '92-'95 Civic before, I will post the link if I find it.
For complete step-by-step instructions (w/photos and part numbers) for installing the Type-R rear swaybar (22mm), go to my website at http://www.geocities.com/bretq/swaybar_install.html
Thanks for providing the link. I tried to download the PDF file you have on there but it said it has exceded bandwidth limits. Do you have it hosted somewhere else where I could get it? Or is it small enough to email?
Thank you kindly in advance.
Ive
I did email the Type-R rear swaybar installation instructions in PDF format to you.
The only suggestion that I have is to just retry periodically.
I Just want to thank you again for that. Very well done write-up!
-Ive
..you own a 92 CX eh?
well you can use any front LCA (lower control arm for short) from any 92-95 Si hatchback or EX coupe or 94+ Integra (any model).
As far as the front swaybar goes, if you want the biggest OEM front bar, the GSR/ITR bar is the biggest to fit your EG - which is a 24mm bar. Yes both ITR and GSR are the same exact bar & endlinks. The next size up is the Si coupe's front swaybar which is 26mm, but I believe that will not fit on a 92-5 civic or 94+ integra at all.
If you do get a GSR/ITR front swaybar, make sure you get the endlinks, rubber d-bracket & bushings.
here's a diagram that will help you out..
....as far as the rear swaybar goes, you can either go Brett's route or....the way I did it was a little different. If you check out Honda-Hybrid's ITR rear swaybar install, you'll see my write up on it. I bought a Prothane D-bracket kit and used that along with the 94+ integra OEM rear mount plates and the rest of the mounting hardware from a stock 94+ integra rear swaybar ON the ITR rear swaybar...
http://hybrid.honda-perf.org/tech/ITRon5G.html
awesome! thanks man after all this posting on multiple boards this is the best answer yet thanks!
hey katman, do you have an aim screen name i'd like to chat with you sometime, you know your pretty famous around these parts (i live in alhambra) anywho sorry to hear about your b17a hybrid (i know it's old news but) anyways hit me up if you have the time my aim screen name is Imported8317 thanks
[Modified by DreamSpeed, 1:09 AM 10/25/2001]
hey, so basically if i go to the junk yard and find a 94-01 integra GSR and just grab the lca the sway bar and all the hardware it should just bolt right in right?
..that's right.
I do have an AIM name, but I don't give it out. I already have too many people hit'n me up in the middle of work. You can always email me though
..that's right.
Thank you kindly in advance and great info about the sway bar mod.
-Ive
ive@axion.net
mynameizstitch
Jul 20, 2009 09:39 PM
ekinshuya
May 31, 2009 07:36 AM
