Does a 98 ITR USDM need a harness for the 2000 JDM ITR Ecu ?
Old Mar 22, 2004 | 10:43 AM
JDM TypeR 307's Avatar
Default Does a 98 ITR USDM need a harness for the 2000 JDM ITR Ecu ?
Well I need a JDM ITR ECU since I'm running a JDM Cat.
My car is a 98 ITR and I was wondering if it needs a hanress for the 00 JDM ITR ECu?
Thanks
Old Mar 22, 2004 | 10:47 AM
Saga's Avatar
Default Re: Does a 98 ITR USDM need a harness for the 2000 JDM ITR Ecu ? (JDM TypeR 508)
It should be a direct PnP.
Old Mar 22, 2004 | 10:50 AM
Asahi's Avatar
Default Re: Does a 98 ITR USDM need a harness for the 2000 JDM ITR Ecu ? (Saga)
What the heck does a JDM cat have to do with a JDM ECU?? What ECU should I run with a test pipe?
Old Mar 22, 2004 | 10:51 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I'm pretty sure a JDM R ECU won't work w/ a USDM engine. Reason being is that JDM R engines have no crank flux sensor, and the VTEC pressure switch is built into the ECU, and is not on the solenoid itself like on USDM engines.
Old Mar 22, 2004 | 10:52 AM
Looose_R's Avatar
youll need an adapter harness or replug your current one
Old Mar 22, 2004 | 10:56 AM
B2FiNiTY's Avatar
I believe it will plug right in. The riceboi just plugged his in... granted it came like that.
Just go obd1 kid.
Old Mar 22, 2004 | 11:39 AM
Mario's Avatar
Default Re: Does a 98 ITR USDM need a harness for the 2000 JDM ITR Ecu ? (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure a JDM R ECU won't work w/ a USDM engine. Reason being is that JDM R engines have no crank flux sensor, and the VTEC pressure switch is built into the ECU, and is not on the solenoid itself like on USDM engines.</TD></TR></TABLE>
It'll work.
The engine will have a few more sensors that the ECU won't need. It's like as if they weren't even there.
Old Mar 22, 2004 | 12:23 PM
mstewar's Avatar
Default Re: Does a 98 ITR USDM need a harness for the 2000 JDM ITR Ecu ? (Mario)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario &raquo;</TD></TR><TR><TD CLASS="quote">
It'll work.
The engine will have a few more sensors that the ECU won't need. It's like as if they weren't even there.</TD></TR></TABLE>
ignoring obd2a and obd2b issues, this is correct.. not sure if the a and b even comes into play though..
JDM ITR ECU goes right into 98 ITRs, i know that much..
kay_animation
Sep 8, 2010 12:42 PM
PIC Performance
Dec 24, 2004 05:50 AM
swlabhot
Jun 5, 2004 01:26 PM
JSJ EG6
Sep 27, 2003 04:36 AM
RedheadRacing
Sep 10, 2002 07:27 AM
