ITR sway bar + Beaks kit
Old Mar 22, 2004 | 10:03 AM
JFG Kevin's Avatar
Default ITR sway bar + Beaks kit
anyone using that set up...what kind of lower tie bar are you using? i heard only the Beaks lower tie bar is the only bar that will fit. true?
Old Mar 22, 2004 | 04:14 PM
JFG Kevin's Avatar
Default Re: ITR sway bar + Beaks kit (aznstyler119)
Bump
Old Mar 22, 2004 | 04:16 PM
GSRBoy's Avatar
before anyone goes nuts on you, search, it's been covered
Matt
Old Mar 22, 2004 | 04:18 PM
IntEGNYC's Avatar
Default Re: ITR sway bar + Beaks kit (GSRBoy)
s e a r c h -the- a r c h i v e s
Old Mar 22, 2004 | 04:26 PM
ThePro's Avatar
I'm not going nuts, but look at http://www.beaksproducts.com
They have a Lower Tie Bar Upgrade kit.
I run that setup with a Neuspeed lower tie bar. The upgrade is longer bolts with a spacer to get the tie bar to bolt up.
The beaks lower tie bar just looks like it hangs down too low for me.
Old Mar 22, 2004 | 09:36 PM
JFG Kevin's Avatar
Default Re: (ThePro)
well...i search aready...didn't come up wiht anythn...if u can find somethin...plz post...
Old Mar 23, 2004 | 12:02 AM
WhoisDan's Avatar
I have an ITR sway bar with the BSQ kit. The Beaks lower tie bar hangs too long for me. I rather go with Benen, Skunk or Carbing.
Old Mar 23, 2004 | 03:21 AM
JBBNJ609's Avatar
Default Re: (aznstyler119)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznstyler119 &raquo;</TD></TR><TR><TD CLASS="quote">well...i search aready...didn't come up wiht anythn...if u can find somethin...plz post...</TD></TR></TABLE>
your lieing
Old Mar 23, 2004 | 04:33 AM
96 Ls lnTeG's Avatar
Default Re: (jason bouchard)
SRR sway an tie bar...
Uncle Jesse
Suspension & Brakes
Jun 30, 2006 07:48 AM
Kyles ej1
Suspension & Brakes
Mar 27, 2005 12:17 PM
salvatore
Jun 26, 2004 09:17 AM
Racer X
Jan 16, 2003 10:56 PM
IntEGNYC
Jan 10, 2003 10:38 AM
