stock muffler...mod?
Old Mar 22, 2004 | 08:30 AM
DIYaccord's Avatar
Default stock muffler...mod?
well, i needed a project for metal shop and i decided to cut open my extra stock "EX" muffler and get all the crap that was rattleing around out.
well, here it is, the inside of a stock honda 94 accord EX muffler:
well, i was just wondering before i weld it back together if there's anything i could do to it to get it to be a little more free flowing or even sound a little big throatyer without making it too loud.
advice anyone...no, i'm not trying to make a performance muffler (i already have an apexi n1 on the car) just seeing if i could do anything to this one.
or another option, would be to just weld it back together and leave it alone...either way sounds good to me.
Old Mar 22, 2004 | 08:31 AM
DIYaccord's Avatar
Default Re: stock muffler...mod? (DIYaccord)
i was thinking welding on some 2" outlet pipe's to make it look alittle sportyer
Old Mar 22, 2004 | 10:40 AM
fw190bvi's Avatar
what is ur reason for this???........u coule always gut it, run a pipe from the inlet, create a new outlet and seal up the holes from the origional outlet, fill it w/ steel wool.....there, now uve got a straight through muffler...
Old Mar 22, 2004 | 11:04 AM
DIYaccord's Avatar
i'd rather keep it quiet
Old Mar 22, 2004 | 11:13 AM
fw190bvi's Avatar
if ur running a resonator, and u pack the steel wool in there good, itll be quiet untill WOT......unless its a free-flowing muffler, its not gonna do much for you IMO......
Old Mar 22, 2004 | 11:27 AM
DIYaccord's Avatar
Default Re: stock muffler...mod? (fw190bvi)
i'm not really trying to get any performance out of this, just asking if i should do anything to it before i weld it back together...
i'll probably just paint the inside with some high temp paint (mostly to make sure nothing rattle's around, then after it's welded shut, spray some more paint throught the pipes.
i mainly was asking if there's anything i can do to what's already in there to get it to be "more" free flowing but not sound like crap...i'm guessing there isn't....
Old Mar 22, 2004 | 12:15 PM
Nick H's Avatar
New User
the paint will just fall off...even the high temp stuff...why are you going to try and make it more free flowing if you aren't looking for performance...???
Old Mar 22, 2004 | 01:07 PM
miedosoracing's Avatar
Let's see. You want it alittle throatier, not worried if it helps, which actually anything to make it throatier would help in performance alittle. Well, look at the two exiting ports. See how small they are. replace those with some larger ones. That will keep it basically the same, but just give it alittle better tune.
Old Mar 22, 2004 | 05:24 PM
DIYaccord's Avatar
Default Re: stock muffler...mod? (miedosoracing)
sorry, didn't know what i was thinking...
i'd like it to perform a little bit better, but i don't want it to sound like crap
that last idea sound good...would i replace the piping with a larger sized diameter piping all the way through replacing the exhaust tips or just the inside piping?
Old Mar 22, 2004 | 05:29 PM
fw190bvi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIYaccord &raquo;</TD></TR><TR><TD CLASS="quote">sorry, didn't know what i was thinking...
that last idea sound good...would i replace the piping with a larger sized diameter piping all the way through replacing the exhaust tips or just the inside piping?</TD></TR></TABLE>
piping.....or else itll just bottleneck off the air, which will then buzz
Old Mar 22, 2004 | 05:55 PM
jwogen1's Avatar
**** if its a diy project for school, go all out maybe you'll stumble onto a production idea--cant hurt to try if its a spare
Old Mar 22, 2004 | 05:58 PM
fw190bvi's Avatar
Default Re: stock muffler...mod? (jwogen1)
i know......rig it up to shoot flames (propane nozzle + spark).....then put it up on Ebay for $500....saying its straight from the 2F2F set......make yerself some cash.....
professorman
Jan 29, 2009 07:27 AM
lv6l
10
Jan 16, 2006 05:25 PM
LShatchie
11
Nov 8, 2005 10:01 PM
DIYaccord
Mar 30, 2004 08:11 AM
mon2mon2
Jul 1, 2002 03:04 AM
