The bloody wheel won't come off (92 cx)
Old Mar 22, 2004 | 05:27 AM
WalkingKenshin
Guest
Posts: n/a
Default The bloody wheel won't come off (92 cx)
ok, its been a very late night, now 9 am. me and my friend dave decided to get stoned and i can't get the wheels off. Now maybe i'm missing something very odd here or this is the matrix.
I took off all 4 lugs, and the wheel did'nt/would'nt come off. Lots of rust on the inner part that rest againts the hub. I could turn the wheel and the axle would move. I don't have to remove the axle bolt do i.. To take off the bloody rim... what is this madness i tell you.
btw, stock 13 steelies(sold him my azenis with rims cheap) mmm.. but yea the ****** would'nt budge, any help would be great. Also is thier an type of washer on the oil pan.. its leaking a little and has a c type clip on it. thanks guys
Old Mar 22, 2004 | 05:30 AM
mafioso102's Avatar
New User
Default Re: The bloody wheel won't come off (WalkingKenshin)
try hitting or kicking the very top part of the tire. Ive found this helps loosen the wheel.
Are you asking if there is a washer for the drain bolt on the oil pan, because if so, then yes there is.
Eric
Old Mar 22, 2004 | 05:35 AM
WalkingKenshin
Guest
Posts: n/a
Default Re: The bloody wheel won't come off (mafioso102)
i know thier is a very little thin one, but this is hudge, like... say 25% as wide as the nut itself
Old Mar 22, 2004 | 05:44 AM
AutoXer's Avatar
No, don't have to remove the c-clip or axle / bearing bolts. Your steelies are just rusted to the hub, it's pretty common. Get a sledge (I have a short handle 5lb that works well) and some penetrating lube (PB blaster, baby.)
Spray the lube around where the hub meets the wheel. Wait a few, tap lightly with the hammer around that area, repeat. Now, hit the hammer around the outer edge of the rim at alternating locations (12:00, 6:00, 3:00, 9:00) Place a block of wood over where you're hitting, if you're worried about damage to the rim. You'll have to hit it pretty hard to break it loose. Eventually it'll break, and if someone's there with you, i've found it may help if they wiggle the tire a little while you're hitting it once it starts to get loose.
To keep this from happening, I use bearing grease or other high temp / pressure grease around the inside of the rim where it meets the hub, and on the outside of the hub. Haven't had a wheel stick yet after that.
Old Mar 22, 2004 | 05:48 AM
Archidictus's Avatar
Unceasing Measure
You could do all that ^^^ or you could just kick the rim a couple times and stop being a girl .
Old Mar 22, 2004 | 06:13 AM
Ricey McRicerton's Avatar
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">You could do all that ^^^ or you could just kick the rim a couple times and stop being a girl .</TD></TR></TABLE>
Yeah, just lay down on your back and start kicking the **** out of the wheel.
Old Mar 22, 2004 | 06:30 AM
Cheivic's Avatar
Default Re: (Ricey McRicerton)
Make sure you have good jackstands though. You could always use a rubber mallet if you don't want to use a sledge.
Old Mar 22, 2004 | 06:35 AM
WalkingKenshin
Guest
Posts: n/a
Default Re: (Cheivic)
nice.. i hope this works.
Old Mar 22, 2004 | 09:37 AM
mafioso102's Avatar
New User
Hahaha, Invader Zim owns jooo!
Old Mar 22, 2004 | 09:54 AM
jcarothers's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, just lay down on your back and start kicking the **** out of the wheel. </TD></TR></TABLE>
lmao, I've done this before.. it's very effective
use this method and some penetrating lube, you'll be done in no time(lube is optional)
Old Mar 22, 2004 | 09:57 AM
B_CRUZ!'s Avatar
kick it!!!
Old Mar 22, 2004 | 10:05 AM
kabaroo's Avatar
BFH - big ******* hammer.
once i had to change a tire for an old lady and it was very rusted on. i kicked it like 20+ times, then it finally popped off. when it pops it can make a noud noise.
Old Mar 22, 2004 | 10:14 AM
Happyman's Avatar
Default Re: The bloody wheel won't come off (kabaroo)
Like they all said...kick one side on the wheel then kick the other keep rotating every couple of kicks you should get it. We used to take turns in autoshop, it was alot of fun.
Old Mar 22, 2004 | 10:30 AM
jdmsiR20's Avatar
Default Re: The bloody wheel won't come off (Happyman)
not to sound like captain obvious or anything, but i hope that the entire wheel is off the ground... completely...
Old Mar 22, 2004 | 11:35 AM
King Tut33's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kabaroo &raquo;</TD></TR><TR><TD CLASS="quote">BFH - big ******* hammer.</TD></TR></TABLE>
Yep, had to use it many times at Wal Mart getting peoples old rusted steelies off the car. Just leave one or two lugs on loose then whack the hell out of the back bottom of the tire.
Old Mar 22, 2004 | 12:09 PM
Powered by Honda's Avatar
Default Re: The bloody wheel won't come off (King Tut33)
BFH's always come in handy in situations like this
Old Mar 23, 2004 | 10:08 AM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WalkingKenshin &raquo;</TD></TR><TR><TD CLASS="quote">ok, its been a very late night, now 9 am. me and my friend dave decided to get stoned and i can't get the wheels off.</TD></TR></TABLE>
******* moron. I hope the car falls on you while you're under it.
efeher
Jul 1, 2011 04:50 AM
preludacris22
Sep 16, 2004 05:01 AM
DEVIN22CBR
Honda Motorcycles
Aug 1, 2004 09:45 AM
Essence of Chicken
Dec 18, 2003 11:21 PM
Lo-Buck EF
Jul 11, 2003 08:44 AM
