Car is lower on one side then the other :(
Welll my car looks nice and low on the front and on the left side of the car the front and rear look really nice but when u look at the right side the rear is higher then the left side .. it is noticeable
i have h&R springs and Tockico adj sturts ... i have my shocks set on 5 on both rears ... i belive but they are werid they don;t click sometimes to maybe the rear shocks are on diff settings for stiffness.. do u think that could bet the problem.? i searched on honda tech for this topic but did not find anything // does anyone know what i should do ?
it has been lowerd for like 1 and a half months i belive and they car is not salvaged i don;t think... i bought it at honda dealership and they di the check point test and wanted a really high price for the car b/c it was in teh best shape for a 94 so i don;t blived anything is wrong with it ... and i douno if it was the installation b/c me and my friend did everything right .. so i don't think that is the problem .. do u think if the shocks are adj. on diff settings it will lower the car or rise it ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integracion »</TD></TR><TR><TD CLASS="quote">I have the same problem, but my setup is H&R Sports on AGX and I only have like 3 weeks whit this setup.
dude that is werid ... like the left side is really nice and the right is like ... did u have a fat bitch sitting on the left side of ur car or something ..... maybe i should get a really fat person to sit in my back sit on the right side maybe that will help :D!!!
</TD></TR></TABLE>dude that is werid ... like the left side is really nice and the right is like ... did u have a fat bitch sitting on the left side of ur car or something ..... maybe i should get a really fat person to sit in my back sit on the right side maybe that will help :D!!!
yeah i should of got some ... but i heard so many good things about H&R springs... oh well i hope one day it will go down and be a good H&r spring
From my experience with springs...i drive the car by my self most of the time...and the springs sag on driver side.what i do...is i switch the springs from the passinger side..to the driver side...and let it settle down again..and switch over agian..
...but i got lazy...and it's sittin side way again..(h&r sport with blues)
I've got the h&r springs and koni yellows. My car looked liked that when I first got them. I've had them for three years now. They finally settle after time and they are now even.
i had the same problem too. i'm using ground control coilover with tokico illuminas. they were uneven when i had them on my stock shocks and the illuminas. good thing i have coilovers that way i can adjust them.
I had that problem once with my coilovers when I changed tires.
What the problem ended up being is the "cup" where the strut and spring go into the body was cocked at an angle. That caused the spring to sit lower in the strut and made it sit higher. Jacked that corner up, got in there with a rubber mallet and gave it a whack. The cup popped back into place and problem solved.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThePro »</TD></TR><TR><TD CLASS="quote">I had that problem once with my coilovers when I changed tires.
What the problem ended up being is the "cup" where the strut and spring go into the body was cocked at an angle. That caused the spring to sit lower in the strut and made it sit higher. Jacked that corner up, got in there with a rubber mallet and gave it a whack. The cup popped back into place and problem solved.</TD></TR></TABLE>
hmmm what u mean what did you hit a cup looking thing?
my passengers side is higher then the drivers side.
H&R race and konis.
but i think i will just move the perch on the drivers side i level up. it should even it out.....
i was wondering about this for a while too.
H&R race and konis.
yea im a big guy i could say... do i need to hit something really hard?? ... get a fat person in my back seat ... ??? to make the srping go dowN?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Groove_D »</TD></TR><TR><TD CLASS="quote">my passengers side is higher then the drivers side.
H&R race and konis.
i was wondering about this for a while too.</TD></TR></TABLE>
Do u think that will work ?
H&R race and konis.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraLs94Cam »</TD></TR><TR><TD CLASS="quote">
hmmm what u mean what did you hit a cup looking thing?</TD></TR></TABLE>
Well, where the spring would go into the chassis, there is a plastic circle to protect the body from the spring. That was the "cup" that came out at an angle. It would be easily noticable if you look where the car is sticking up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC »</TD></TR><TR><TD CLASS="quote">are you sure you dont have the front and rears mixed up with the right and left?
are you serious? last time i checked driver and pass springs are the same.
</TD></TR></TABLE>are you serious? last time i checked driver and pass springs are the same.
