quick question... regarding fuel filter
how the f**k do you remove the bolts off the top of the fuel filter? the 14mm one is easy but the other one is hard, i cant get it to move a bit.. any advise?
I coudlnt get mine off either, Try taping the top to loose the crude, if that doesnt help do to a local mechanic and have him try to use an impact gun
maybe Im wrong but you have to remove the little bolt that's on top of the big one.
be careful with the washers, and make sure you put all of them or you'll be leaking gas, learned the hard way.
go here download the workshop & service manuals
http://www.acute.f9.co.uk/crx/...s.htm
good luck
I removed the service bolt, then soaked the banjo (2 sided bolt) with penetrant, tapped on it and used a vise grips to break it loose.
