HELP! 98 gsr motor into a 94ls
hey fellow memeber, i need some info cause im trying to complete this asap.
i have a 98 gsr motor swapping into a 94 ls.
what do i need to make this work?
ive searched and only found that i might need a 94-95 distributor, injectors, and alternator, and ecu?
correct me if im wrong or if i need anything else
thanks
thanks
Are you referencing just the engine? Or a complete swap? If it's just the engine then you'll need to invest in a different intake manifold as well. You will need the OBD-1 dizzy, injectors, ECU, and other OBD-1 exclusive pieces. Also, you will need to run the appropriate wires for the VTEC solenoid, pressure switch, chassis ground, and whatever is necessary for the GSR intake manifold assuming you use a stock manifold as opposed to a Skunk2 or other aftermarket manifold.
ive searched...like i stated above
thanks Kendall
im going to use a skunk 2 manifold, but the gsr motor is complete with manifold, i use the manifold, can i use the injectors off of there? i have a 94 ls motor and i have a complete 98 gsr engine that i want to swap. can i use any of the obd1 parts off my ls? as far as your comment above, if i have the complete swap, what do i exactly need?
thanks
TTT
thanks Kendall
thanks
TTT
You can just find the harness for the GSR motor and do everything OBD2. It should all plus in that way you dont have to rewire the injectors. Then just get the ecu jumper and convert it to OBD1.
and not to mentioned you need to wire the vtec soleniod and you have to change your whole wiring to gsr!!! Might as well change your engine wiring harness. To save you some trouble!!!! ls don't dave a vtec wiring!!!
miguel329
Jan 27, 2008 09:25 PM
zipperchamp
Dec 25, 2007 07:12 AM
theslugbug
Sep 29, 2004 05:11 AM
