help - engine tick from h22a4 - troubleshoot
Old Mar 21, 2004 | 09:33 PM
danmanh22's Avatar
Default help - engine tick from h22a4 - troubleshoot
i recently pulled the valve cover - when replacing it, i got a fairly good amount of oil got into the #3 cylinder through the spark plug hole (devoid of plug). i sucked out as much oil as i could, but there is still prob a bit left in there. i started motor, and tick-tick-tick-tick (as fast as rpms) coming from motor near #3 cylinder.
i pulled the spark plug for a sec and it had a good coat of oil on it. there is only a lil left in there but i dunno what to do to get it out! please help
it was suggested to me to pour a lil bit of water into each cylinder through spark plug hole and then run motor for a bit to kind of "steam clean" the engine and break some carbon off from the inside of the exhaust. i am going to try this if i dont get any better ideas.
Old Mar 21, 2004 | 10:16 PM
Kavehman's Avatar
Default Re: help - engine tick from h22a4 - troubleshoot (danmanh22)
dude if you pour water into teh cylinders i think that will blow the thingup, If it were me id just clean off the spark plug and put it back in there and let the cylinder burn the oil off, dont pour anything else in their, last time i check water doesnt really clean oil
Water Doesn't combust
Old Mar 21, 2004 | 10:27 PM
danmanh22's Avatar
Default Re: help - engine tick from h22a4 - troubleshoot (Kavehman)
the water idea came from a pretty reliable source - he mean just a lil water not a lot, but if you say its a bad idea, than maybe thats it.
however, could this ticking noise from cylinder 3 be something else maybe? im pretty sure the oil is the prob - would not firing due to oil in the cylinder cause a ticking noise?
Old Mar 21, 2004 | 10:38 PM
NoLipRacen's Avatar
the ticking noise might just be your valves so i would check those... but definetly do not pour water into you cylinders you WILL kill your motor, like stated above water does not combust nor does it compress...
Old Mar 22, 2004 | 12:11 AM
danmanh22's Avatar
Prolly not valves - before i pulled the valve cover, everything ran ok - while it was off, i didnt touch valves - then when i put the cover back on, the ticking began. im pretty sure its the cylinder not firing because of the wee bit of oil in it... but not positive
Old Mar 22, 2004 | 06:57 AM
AndyGCT's Avatar
Default Re: (danmanh22)
might just need a valve adjustment...I read a lot on searches for this problem because i have the SAME issue...I'm having a friend do my timing belt and auto tensionors this weekend and will do the valve adjustment at the same time...The belts wont effect it obviously but PM me your email address I'll let you know if the valve adjustment took care of the ticking...Therefore you wont burn a lot of money on different tests...
Old Mar 22, 2004 | 01:34 PM
vtecludeh22's Avatar
I want to know is your car smoking at all when YOU get on. If so oil is getting into ur cyclinder (you probably knew that) . I had that same problem and one of the reasons was the gasket around the spark plugs were bad and oil was was sliping through the threads. I would check that.
Old Mar 24, 2004 | 07:52 AM
danmanh22's Avatar
Default Re: (vtecludeh22)
yep def smokin behind me when i romp the throttle... iono cars in the garage for a while. ill beat on it in a week when i come home an see if i can dry up that cylinder...
Old Mar 28, 2004 | 03:49 AM
danmanh22's Avatar
bump bump bump does anyone else have an idea 'bout what else i can do to solve this problem?
also, does anyone have a good writeup of, or know the url of a good writeup for valve adjustment clearances for a 97-01 prelude? im pretty sure the exhaust and intake clearances are around .007 - .008, but i dont want to guess. i'd like it perfect.
thanks for the help
Old Mar 28, 2004 | 05:51 AM
biglew's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danmanh22 &raquo;</TD></TR><TR><TD CLASS="quote">bump bump bump does anyone else have an idea 'bout what else i can do to solve this problem?
thanks for the help </TD></TR></TABLE>There is a good deal of valuable info in searching and at the top of the Prelude forum there is a thread thats called Essential Prelude Links where this is linked.
https://honda-tech.com/zerothread?id=618786
Old Mar 28, 2004 | 08:27 PM
LudEcrous's Avatar
it was suggested to me to pour a lil bit of water into each cylinder through spark plug hole and then run motor for a bit to kind of "steam clean" the engine and break some carbon off from the inside of the exhaust. i am going to try this if i dont get any better ideas. </TD></TR></TABLE>
Whoever told you that should be shot.
As stated before you should check your valve lash.
_EF9
Nov 9, 2014 04:20 PM
TarikSwift
Apr 7, 2010 07:56 PM
HCJDM1
19
Dec 12, 2007 09:41 AM
wiscteg
Nov 25, 2005 08:09 PM
B18Redline
Nov 29, 2004 11:39 AM
