H22a Swap from an H23
Old Mar 21, 2004 | 08:31 PM
IMPORTMyth01's Avatar
Default H22a Swap from an H23
Whats up just have a normal question, I am taking out a blown up h23 motor out of my lude and want to put a h22a into it...besides running the Vtec wires is there anything else that would not be transferable between the two...such as motor mounts, shift cables, sensors etc.?
One more thing... would it be worth taking out the factory butterflies and running a p30 ecu? If so how hard is the process? Thanks
Old Mar 21, 2004 | 08:38 PM
PrecisionH23a's Avatar
Default Re: H22a Swap from an H23 (IMPORTMyth01)
Swap:
http://www.jrcormier.com/prelude/engineswap.php
http://www.superhonda.com/foru...41207
Removing butterflies:
https://honda-tech.com/zerothread?id=648786
https://honda-tech.com/zerothread?id=634796
ECU: P13
Your Friend:
https://honda-tech.com/zerosearch
Old Mar 22, 2004 | 04:15 AM
Default Re: H22a Swap from an H23 (PrecisionH23a)
thanks dog that helped alot...peace
Old Mar 23, 2004 | 05:54 AM
CHK4TIX's Avatar
hey if you need the ecu pins, I still have a few left.
Old Mar 23, 2004 | 08:13 AM
prelittlelude's Avatar
Default Re: H22a Swap from an H23 (CHK4TIX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHK4TIX &raquo;</TD></TR><TR><TD CLASS="quote">hey if you need the ecu pins, I still have a few left. </TD></TR></TABLE>
ah the man himself, glad to see your still around
Old Apr 6, 2004 | 05:36 PM
NobodysHero's Avatar
Will my H23A1 tranny fit ok with my JDM H22A?
Old Apr 6, 2004 | 05:52 PM
AndyD's Avatar
Default Re: (whitetrash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whitetrash &raquo;</TD></TR><TR><TD CLASS="quote">Will my H23A1 tranny fit ok with my JDM H22A?</TD></TR></TABLE>
Yes
Old Apr 6, 2004 | 06:06 PM
awsome thanks (I've been lied to about stuff like that before)
Old Apr 9, 2004 | 10:14 AM
Citystar's Avatar
my name is will i live in south carolina.i just swaped the 153k h23 out of my 92 si lude with a 42k jdm h22a front clip.i took out everything out of the clip and put it to mine. i also used the stock wiring harness.u can run the vtec wires seperate through wires to the vtec ecu.let someone do it that knows what they are doing.alot of things were alittle different from my h23 and h22.
Old Apr 9, 2004 | 10:15 AM
Citystar's Avatar
Default Re: (NobodysHero)
yes it will fit to the jdm h22a
Old Apr 9, 2004 | 10:35 AM
Honda Sport's Avatar
not that many things are different. the only things I can think of are the fuel rail, distributor, and crank pulley. other then that, it's a straight swap over.
Old Apr 11, 2004 | 06:22 PM
jdmlude_dude's Avatar
Default Re: (Honda Sport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Sport &raquo;</TD></TR><TR><TD CLASS="quote">not that many things are different. the only things I can think of are the fuel rail, distributor, and crank pulley. other then that, it's a straight swap over.</TD></TR></TABLE>
why would the fuel rail, distributor and all that matter if you have a full swap or long block. The distributor would the only thing cause the jdm distributor has an internal coil and usdm one uses an external coil. Other than that, no differences. The crank pulley, which is actually called a harmonic balancer, would already be on the motor, no need to swap them. If you get a short block or try to piece an h23 together, then worry about that stuff!
Old Apr 12, 2004 | 08:39 AM
Default Re: (jdmlude_dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmlude_dude &raquo;</TD></TR><TR><TD CLASS="quote">
why would the fuel rail, distributor and all that matter if you have a full swap or long block. The distributor would the only thing cause the jdm distributor has an internal coil and usdm one uses an external coil. Other than that, no differences. The crank pulley, which is actually called a harmonic balancer, would already be on the motor, no need to swap them. If you get a short block or try to piece an h23 together, then worry about that stuff! </TD></TR></TABLE>
DUDE!...if he's talking about doing a h23a1 swap to a JDM h22a swap, YEAH, you need to do something about these things. the JDM h22a crank pulley is 5 threaded VS the alternator h23a1 4 threaded alternator pulley. you can just reuse your 4 threaded belt like I did. on the fuel rail, the fuel line comes in from the opposite side on JDM preludes VS USDM preludes. that's why you reuse your old h23a1 fuel rail or you can make a custom line for the fuel rail. and yes, just reuse the h23a1 dizzy and coil if you don't want to re-wire the internal coil JDM h22a distributor. I've done this swap on my own car so I'm positive on what you need to have done.
Boostless97Lude
Sep 24, 2011 10:30 AM
b-rads...si
Dec 8, 2007 04:17 PM
BrockNB
Oct 17, 2006 03:24 PM
JDM_4thGen
Sep 10, 2002 06:21 PM
