Tech help please
Old Mar 21, 2004 | 08:13 PM
JSPECEX's Avatar
Default Tech help please
I just replaced my headgasket and i did everything to spec but now i can't get it timed. actually i have it timed fine just when i hook up the iac the idle goes crazy and if i unplug it the car runs perfectly fine besides the check engine light and the harsh throttle response due to the iac not keeping pressure. i wonder if i damaged it when i cleaned the throttle body with penatrating spray. the only other thing i could thinkn of would be maybe the timing belt slipped a tooth but i can get the idle fine without the iac. so if anyone has had a similar problem or is a tech and ca answer this please help. thanks
Old Mar 21, 2004 | 08:56 PM
918-Hatch's Avatar
Colorado <3
bump
Old Mar 21, 2004 | 09:10 PM
JSPECEX's Avatar
Default Re: (918-Hatch)
thanks for the bump i really need to figure this out i need to sell the car very soon
Old Mar 22, 2004 | 07:45 AM
JSPECEX's Avatar
Default Re: Tech help please (JSPECEX)
somebody help please i am stuck with nowhere to go from here. please any ideas
Old Mar 24, 2004 | 08:03 PM
JSPECEX's Avatar
bump
Old Mar 24, 2004 | 08:17 PM
REDGEAR's Avatar
Bump
Old Mar 25, 2004 | 07:38 AM
JSPECEX's Avatar
Default Re: Tech help please (REDGEAR)
guess i am not the only one who can't figure it out
Old Mar 25, 2004 | 09:03 AM
BatuKing's Avatar
when you cleaned it with penatrating spray,, what kind was it?
Old Mar 25, 2004 | 05:42 PM
JSPECEX's Avatar
Default Re: Tech help please (BatuKing)
not sure is it like fords where the have that film around it and if you use carb cleaner you destroy it. i hope not
i am aiming towards the timing belt bieng wrong but i haven't had time to look yet
Old Mar 25, 2004 | 05:49 PM
2lua's Avatar
use tb cleaner, and clean your iac, if that didn't help clean your fitv under the tb.
Old Mar 26, 2004 | 05:33 PM
JSPECEX's Avatar
Default Re: Tech help please (2lua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua &raquo;</TD></TR><TR><TD CLASS="quote">use tb cleaner, and clean your iac, if that didn't help clean your fitv under the tb.</TD></TR></TABLE>
what is the fitv, i already cleaned the iac
Old Mar 26, 2004 | 05:39 PM
2lua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECEX &raquo;</TD></TR><TR><TD CLASS="quote">
what is the fitv, i already cleaned the iac</TD></TR></TABLE>
fast idle thermal valve.
Old Mar 28, 2004 | 11:06 AM
JSPECEX's Avatar
alright thanks i will check it out. i hope i just got some dirt in there
BLK_TEG_007
Mar 26, 2008 10:36 PM
egyolk
Sep 19, 2005 08:19 PM
PowderB16
Jan 8, 2005 09:27 PM
EFin' Kyle
Dec 6, 2004 06:24 PM
Br1anPham
Jan 27, 2004 07:22 PM
