Tech help please
Tech help please
I just replaced my headgasket and i did everything to spec but now i can't get it timed. actually i have it timed fine just when i hook up the iac the idle goes crazy and if i unplug it the car runs perfectly fine besides the check engine light and the harsh throttle response due to the iac not keeping pressure. i wonder if i damaged it when i cleaned the throttle body with penatrating spray. the only other thing i could thinkn of would be maybe the timing belt slipped a tooth but i can get the idle fine without the iac. so if anyone has had a similar problem or is a tech and ca answer this please help. thanks
Re: Tech help please (BatuKing)
not sure is it like fords where the have that film around it and if you use carb cleaner you destroy it. i hope not
i am aiming towards the timing belt bieng wrong but i haven't had time to look yet
Re: Tech help please (2lua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua »</TD></TR><TR><TD CLASS="quote">use tb cleaner, and clean your iac, if that didn't help clean your fitv under the tb.</TD></TR></TABLE>
what is the fitv, i already cleaned the iac
Re: Tech help please (JSPECEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECEX »</TD></TR><TR><TD CLASS="quote">
what is the fitv, i already cleaned the iac</TD></TR></TABLE>
fast idle thermal valve.
egyolk
09-19-2005 08:19 PM
PowderB16
01-08-2005 09:27 PM
