brake light in dash problem
Old Mar 21, 2004 | 08:04 PM
JforJonathan's Avatar
Default brake light in dash problem
i got a 00 civic si and my dash brake light stays on. It gets brighter when i pull up on the e-brake. I checked the fluid, and it was maybe a little low, so I filled it up. The light is still on though. what can my problem be? do i need to reset the ecu?
Old Mar 21, 2004 | 10:54 PM
chameleon's Avatar
Default Re: brake light in dash problem (Dj Villain)
check if you have a taillight out, i believe that would be the other indicator for that light to remain on, the main thing is definitely the brake fluid i guess make sure the wires that run to your master cylinder cap are fine.
Old Mar 22, 2004 | 08:59 AM
Default Re: brake light in dash problem (chameleon)
i will check my lights to make sure if they are all working. ill let u know what happens
josejdm
Sep 28, 2009 12:03 PM
ef9gsx
17
Dec 15, 2007 01:49 PM
RedSuperRanger23
Dec 6, 2006 04:27 PM
ingyplz
Jul 23, 2006 06:49 PM
AZNBIGPIMPN505
16
Feb 10, 2005 11:00 PM
