Starting installing my Tyrus Intercooler
Here is a few pics of my progress thus far. I just ordered my mandrel piping so I got to wait for it to get here then cut it to fit then get what I can welded up.
lookin good glad to see anotehr sr20 on the boards, i gotta put in my clutch and get my **** tuneddddddddddddd !!!
nice i just ordered that same intercooler, and its bigger then i thought, thats the 5" one right?
where'd u order ur mandrel piping from.. and how long did it take to get ur intercooler?
just curious, looked good tho
how do those ser's run ?? 1/4 mile wise on a low budget turbo setup
edit: can a regular sentra be swapped with the g20 sr20de?
Modified by 4G63 at 3:53 AM 3/22/2004
You can swap a SR20 into just about any Sentra. As far as how they run I run in the 13's on street tires consistently at 5600' above sea level on about 10psi of boost with a full exhaust including a converter. Im thinking that it is a 12 sec. car at sea level with some slicks. The runs that I previously did were all with a small stock top mount intercooler or interheater whatever you want to call it (haha).
As far as the brackets I will try to remember to take some pics tomorrow of them.
I need to get this thing dyno'd after this intercooler upgrade is done. I have heard as much as 20 hp is to be had in upgrading from a top mount intercooler to a front mount intercooler?
Got my mandrel piping in last Friday but was out of town this weekend so I havent finished my car up yet. I bought four 2.5" 180* u bends from JC Whitney. I hope that is enough to finish the whole job?
Lets see specs are
1992 Nissan Sentra SE-R
Bluebird SR20DET Swap
Hallman Manual Boost Controller
Clutch Specialties Stage 2 clutch
Apex SAFC
MSD 6AL
That is it for the engine I think? haha
Kosei K1's
Ground control coilovers/KYB Shocks
Full Energy Suspension bushing and motor mount insert kit
Front strut tower bar
I think that is it for the suspension side of it?
Lightened up the car some also by taking out the power steering rack and installing a manual rack, removing the sound deadening, all the junk in the trunk, removed the a/c stuff, and I think that is about it. Im sure Im forgetting something though.
Im glad to see that someone thinks that my old beater is nice or clean!! I cant wait until I get the time and money to tear it down and start again from bottom up. Then maybe I will think it is nice or clean when its basically a brand new car!
Apex SAFC
MSD 6AL
Kosei K1's
dude, i feel like an idiot...the first thing i thought when i saw the ic, was..."is that thing made out of paper or something? will it hold boost?" then i realized that its just cardboard....yah, but it looks nice...fits right under that bumper, dont it?
For those of you who are getting that same intercooler:
I would highly suggest getting one that is either taller, or not as wide. Putting air through something that is only 5 inches tall and about a mile long is going to add some solid pressure drop.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpt4321 »</TD></TR><TR><TD CLASS="quote">For those of you who are getting that same intercooler:
I would highly suggest getting one that is either taller, or not as wide. Putting air through something that is only 5 inches tall and about a mile long is going to add some solid pressure drop.</TD></TR></TABLE>
My 5"worked fine, and it has for many other people, i recommend it
well i just went out and looked at my intercooler and stuff with one of my mandrel bends in hand. I think that I have enough more than likely I just need to get a chop saw or something so i can make the cuts on the piping fairly clean. Once that is done its pretty much getting the piping welded what i can and installing it on my car. Then comes the most fun beating the **** out of it with my new intercooler
Looks good, i wish i had the time/money to turbo my 91 classic. I'm just gonna go with boltons and a 100 shot/slicks.
Anyways good luck with your project, i rode in my friends 94 classic with a 57 trim t3/t04E @ 10 psi and it was nuts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITSTOCK »</TD></TR><TR><TD CLASS="quote">
Worked "fine" and "optimal" are two very different things.
If you're going to buy a FMIC, you might as well buy the best one out of your choices.
</TD></TR></TABLE>Worked "fine" and "optimal" are two very different things.
