Radio Not Working
Old Mar 21, 2004 | 05:47 PM
Rexus Rick's Avatar
Default Radio Not Working
So I'm driving hometoday, and my radio and my clock just turns off and I ca't get it to turn back on. DO you think it would be a fuse or bad wiring?
Old Mar 21, 2004 | 05:56 PM
juanb's Avatar
yes more that likely its a bad fuse just check them.
Old Mar 21, 2004 | 06:27 PM
ceLtic's Avatar
N/A wh0re!
Default Re: (juanb)
fuse. use correct ones, if not they'll go bad. or since your speaker/radio/system uses a lot of watts, replace it with a higher wattage one. or voltage whatever
Old Mar 21, 2004 | 06:43 PM
91civicEX's Avatar
Default Re: (chrism)
if your domelight also doesnt work then its a fuse.
Old Mar 21, 2004 | 06:46 PM
EF9Dreams's Avatar
Default Re: Radio Not Working (Rexus Rick)
could be fuse and or wiring... check it all....
Old Mar 22, 2004 | 12:49 PM
Rexus Rick's Avatar
What is the fuse number on that? and wattage....amps....whatever. I need to replace it after work and I have my manual in the garage. By the way, it is a 90 CRX Si.
Old Mar 22, 2004 | 03:20 PM
Rexus Rick's Avatar
Bump
Old Mar 22, 2004 | 03:23 PM
EL Vap133's Avatar
Default Re: (Rexus Rick)
Just look under the fuse cover, it should say. Or look for the burnt fuse.
Old Mar 22, 2004 | 03:31 PM
flatty's Avatar
sorry man but if you can't change a fuse you should ride the bus
Old Mar 22, 2004 | 03:34 PM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
hahah...funny comin from a guy name fatty...sike...anyways...listen to el vap and check the fuse panel, then the fuse, if worse comes to worse check the wiring....
NACvicSi
Aug 27, 2009 05:03 PM
Mishima
Jun 30, 2009 09:08 PM
LUDE21
May 31, 2007 01:52 PM
STN_Pat
Jul 22, 2006 05:46 PM
tuan...
Aug 7, 2004 05:47 AM
