Burning oil, oil spots all over the back bumper.
I have a 99 si motor with skunk2 cams and springs and retainers. I've done a compression test and it was all good. So it's not the rings. What do you guys think it problem is? I washed the car and now it has oil spots all over the back bumper. Seems like it's spitting out oil. The oil is getting low though.
Modified by Snail EK at 5:04 AM 3/22/2004
clean your pcv valve and use a touring type filter on your valve cover instead of the tube to your intake. it allows all the unexhausted fumes to exit instead of rentering the head. try having an engine flush to clean up all that build up.
B20inDCinLBC
12
May 22, 2009 07:53 AM
