Im having fuel problems:(
Old Mar 21, 2004 | 01:40 PM
civic859's Avatar
Default Im having fuel problems:(
I just done a swap in my 1996 civic. I droped a JDM b16. I turned the key and the engine cranks strong but wont turn over and run. I sprayed some engine start in the intake manifold and it ran for about thirty seconds then shut of. There is no fuel getting to the fuel filter thus none to the fuel rail. What could be the problem? When I started there was no problem with my fuel pump so im wondering if there could be another problem before I go buy a new one?
Old Mar 21, 2004 | 11:13 PM
chameleon's Avatar
Default Re: Im having fuel problems:( (civic859)
when you turn your key to the ON position do you hear your pump prime? if it isnt then your main fuel relay took a ****. if it is priming then you should be getting fuel to the filter and so on unless u got a nasty clog, then time for a new filter.
Old Mar 23, 2004 | 10:46 AM
PnX-R's Avatar
I'd also check the fuse..
mikester1222
Nov 16, 2008 05:16 PM
Slyfox_racer
Sep 16, 2007 01:04 PM
Slyfox_racer
Sep 13, 2007 03:17 PM
diewX3
Jan 11, 2005 11:50 AM
hair_rice
Jul 5, 2004 07:37 PM
