For the Turbo pros, I really need your help.
I have a problem with violent jerking with my car when I'm cruising and the car is under vacuum. The problem is intermittent and mainly happens when I'm driving long distance 90+ miles or so, or when I'm driving the car really hard under boost and as soon as it under vacuum a little after boosting, the car would jerk violently and uncontrollably.
Mods: Built and sleeved LS engine, Bosch 550 cc injectors, t3/t4 turbo, intercooler, AEM fuel rail, upgraded fuel lines, SARD fpr, Tial wastegate, cam gears, 3.00" exhaust, Bosch intank fuel pump, MSD 6AL, MSD blaster 2 coil, Hondata 2B, 3 BAR map sensor, Apexi AVC-R....
Fuel, electrical or ignition problem?
does it happen right after you let off the throttle? I had the same problem and it turned out to be a boost leak. Check for leaks, it cant hurt and odds are that you have a few, even if that isnt the problem.
how would i check for boost leaks? also, it happens when i run the car extremely hard or during long distance trips at cruise the whole trip.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy »</TD></TR><TR><TD CLASS="quote">okay sorry you have hondata, its probably in your tune. Ar you running lean when it happens?</TD></TR></TABLE>
unfortunately, I don't have a wideband in the car and don't know if it is leaning out. hopefully, that isn't the case.
i believe the problem could be caused by these parts (feel free to correct me if i'm wrong):
-distributor
-3 BAR map sensor
-MSD external coil
-MSD 6AL
-ignitor
-injectors
-fuel pump
-FPR
-distributor
-3 BAR map sensor
-MSD external coil
-MSD 6AL
-ignitor
-injectors
-fuel pump
-FPR
i was having the same problem and ran a diagnostics for the check engine light.. Turned up being an 02 senser problem. I looked under the car and found that one of my sensor wires was ripped in half, so i twisted it together and it fixed the problem
My guess is definitely O2 sensor problem. I had a similar problem, only surfaced after long trips. Turned out the longterm fuel correction factors has changed to a point that the car was running so lean it was misfiring. Fixed the O2 sensor problem and never had an issue since.
