JDM h23 V-Tec pic
I searched but no pics of the actual sensor with a <U>plug plugged in</U>. Heres the pic, The sensor seems to be turned a bit farther then my gs-r as far as where the notch is on the outer part of it--Circled in red. ans the pic was blurry so i drew over them
so what i need to know is which one is the ground because i don't have the originaL plug for it so my wires are different colors. the left one closest to the notch or the right one?
Modified by b18c1civic95 at 12:17 PM 3/21/2004
i believe its the bottom pin, you know you can just use any 2pin plug for it, if it dont work then just switch the pins, its just an on/off switch nothing complicated. you could have figured that out in 2 min or less. damn noobs
yeah i know i can use any plug as far as that goes. thats why i said i dont have the
<U>ORIGINAL</U>. i figured it out after lookin at some other motors. I just wasnt sure about voltage goin to it and that being reversed. didnt wanna end up fryin somethin. but thanxs. Who said anything about polarity?? i SAID the voltage. and yur noob comment is just a tad bit played out.
Modified by b18c1civic95 at 9:08 AM 11/3/2004
skUnK2jdm
10
Feb 9, 2008 10:00 PM
yohan
Sep 14, 2004 04:03 PM
