do i need larger injectors/fuel pump?
If you need larger anything, you would need injectors. 270s or 310s. Some are fine with B18C5s and Bs, but when they add a test pipe, it all changes. You will have a little more compression.
Jason
Jason
The only way to know for sure, it to install all those components and then if you have to keep raising fuel pressure to keep it from going lean then you step up the injectors. I doubt you'll need a fuel pump unless you plan to run at high fuel pressure which in your case you won't need to. Don't buy em unless you know for sure you need em.
deucedeuceEK
Jun 2, 2007 04:33 AM
