squeeking steering wheel, 91 civic dx
Old Oct 21, 2001 | 04:49 PM
civic2299's Avatar
New User
Default squeeking steering wheel, 91 civic dx
Hey there, anybody know how to remedy a sqeeking non power steering wheel.Thanks
Old Oct 21, 2001 | 06:13 PM
4wsB21a's Avatar
New User
Default Re: squeeking steering wheel, 91 civic dx (civic2299)
take it off.
Old Oct 21, 2001 | 07:39 PM
BreakStuff's Avatar
New User
Squeeky steering wheels can be the cause of..
Turn Signal Cancel Cam, located just behind the steering wheel..
Steering Column Linkages
Steering Column Rubber Grommet on the firewall
Steering Rack
My bet and the easiest of the 4 would be to spray the steering column likages underneath the dashboard with a lubricant such as Silicone, WD-40, PAM
You will have a black plastic cover the surrounds the column, you can either remove it or drill access holes in it, spray the linkage knuckles and where the linkage meets the firewall, lube the above while moving the steering wheel back and forth... That should do it..
Old Oct 21, 2001 | 09:32 PM
Gasoline Fumes's Avatar
Default Re: squeeking steering wheel, 91 civic dx (BreakStuff)
I've had the horn contact squeek on my Wagon.
civic4life8045
18
Jun 5, 2013 09:10 AM
breanna
Feb 28, 2006 12:51 AM
choi830
Oct 30, 2003 05:13 AM
