Pedals installed. Feesl strange. Question
Old Mar 21, 2004 | 08:34 AM
Ex-ITR5874's Avatar
Default Pedals installed. Feesl strange. Question
Last week I installed a set of pedals... The work (drilling etc.) went straight and I was satisfied at the end... But now the brake pedal feels "soft"... Feels like I`ve to press the pedal 20% harder to achieve the same result.. I checked the hoses, fluid, pads, rotors... everything seems normal. I`m out of possible answers... Anybody ?
Before you begin to wonder: Brake pedal is directed to 1 o`clock position to support revmatching...
Old Mar 21, 2004 | 09:06 AM
onePOINTsix's Avatar
Default Re: Pedals installed. Feesl strange. Question (ITR5874)
your imaging things, it's tghe same as before you just didnt relise it
Old Mar 21, 2004 | 10:05 AM
PriMaTe's Avatar
Default Re: Pedals installed. Feesl strange. Question (Sideout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideout &raquo;</TD></TR><TR><TD CLASS="quote">your imaging things, it's tghe same as before you just didnt relise it</TD></TR></TABLE>
yea i think you're imagining it too, all you did was stick some covers on your pedals it won't affect anything. I think it's just cause you're not used to your pedal being a little thicker(since there is a cover on it adding thickness) and having a different surface than stock.
Old Mar 21, 2004 | 06:46 PM
mikestypeR
Guest
Posts: n/a
Default Re: Pedals installed. Feesl strange. Question (PriMaTe)
i agree pedal covers will not chang anything .... "shakes head"
Old Mar 22, 2004 | 03:18 AM
Ex-ITR5874's Avatar
Default Re: Pedals installed. Feesl strange. Question (mikestypeR)
I`m not a n00b. I know installing pads doesn`t change anything normally. But the pedal feels soft and I`m looking for the answer what might have been happend during the install what causes that.
Thanks anyway...
Old Mar 22, 2004 | 06:14 AM
Philly_NBP_R's Avatar
if the pedal feels softer, just bleed the brakes, and see if that helps...
Old Mar 22, 2004 | 10:14 AM
B2FiNiTY's Avatar
Default Re: Pedals installed. Feesl strange. Question (Philly_NBP_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R &raquo;</TD></TR><TR><TD CLASS="quote">if the pedal feels softer, just bleed the brakes, and see if that helps...
Exactly.
Old Mar 22, 2004 | 10:32 AM
Arsenal's Avatar
Default Re: Pedals installed. Feesl strange. Question (B2FiNiTY)
Maybe because you are now pushing down on a larger surface area than before
Old Mar 22, 2004 | 12:48 PM
nfn15037's Avatar
Default Re: Pedals installed. Feesl strange. Question (Arsenal)
Maybe the pedal covers are cheap and they are deflecting under the force of your foot? I noticed a difference in pedal feel when I took the rubber pads off my pedals and replaced them with skateboard grip tape, so maybe you are not imagining things?
Old Mar 22, 2004 | 02:32 PM
Default Re: Pedals installed. Feesl strange. Question (nfn15037)
no, OMP pedals are high quality pieces - they are metal, not cheap plastic. He just needs to bleed his brakes...
Old Mar 22, 2004 | 02:44 PM
TYPEROLLER#420's Avatar
Nighthawk7thGen
Honda Civic (2001 - 2005)
Nov 13, 2007 12:24 AM
josephshark
12
Dec 19, 2005 01:34 PM
2Point3LiterVTEC
Feb 8, 2005 08:57 PM
onyx00
Jun 11, 2004 10:42 PM
BeerMan
Jun 11, 2003 10:33 AM
