D16Y8 INnake manifold Auto and manual the same?
Old Mar 21, 2004 | 08:34 AM
Stoich's Avatar
Default D16Y8 INnake manifold Auto and manual the same?
I wanted to know if i would run in to any problems using a intake mani from a auto on my 5spd car ive heard that its different and cant be used?
ideas?
Old Mar 21, 2004 | 11:53 AM
EG8R's Avatar
Default Re: D16Y8 INnake manifold Auto and manual the same? (Stoich)
It can be used and modified to work. I modified mine but have not put it on.
Old Mar 21, 2004 | 11:59 AM
JSPECHB's Avatar
Default Re: D16Y8 INnake manifold Auto and manual the same? (skelly ed6)
Manual Cars=IAC
Auto Cars=NO IAC
Old Mar 21, 2004 | 12:07 PM
FAST AS's Avatar
Default Re: D16Y8 INnake manifold Auto and manual the same? (JSPECHB)
i have one for $25 dollars off of auto
Old Mar 21, 2004 | 12:29 PM
BlackCRX's Avatar
get the manual one if possible
you can mod the auto but its a pain in the *** cuz you ahve to drill and align 2 drill holes
Old Mar 21, 2004 | 01:42 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECHB &raquo;</TD></TR><TR><TD CLASS="quote">Manual Cars=IAC
Auto Cars=NO IAC</TD></TR></TABLE>
Manual Cars=2 wire IACV on manifold
Auto Cars=3 wire IACV on throttle body
This may help with the install...
http://www.geocities.com/joeyp....html
Old Mar 21, 2004 | 02:35 PM
Stoich's Avatar
Default Re: D16Y8 INnake manifold Auto and manual the same? (fastcrxsi90)
here are 2 which is which?
http://cgi.ebay.com/ebaymotors...sting
http://cgi.ebay.com/ebaymotors...%3AIT
Old Mar 21, 2004 | 05:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stoich &raquo;</TD></TR><TR><TD CLASS="quote">
http://cgi.ebay.com/ebaymotors...sting </TD></TR></TABLE>
looks like a z6 manifold
http://cgi.ebay.com/ebaymotors...%3AIT</TD></TR></TABLE>
auto y8 manifold (from 2000...has air injection deal...)
Old Mar 21, 2004 | 05:36 PM
Stoich's Avatar
so how do i tell them apart in pics?
Old Mar 21, 2004 | 07:48 PM
EG8R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stoich &raquo;</TD></TR><TR><TD CLASS="quote">here are 2 which is which?
The first one looks like an A6 but its got me a bit confused....
The second one is a Y8 BUT 99 and 2000 do not bolt up easy! You must shaved off the whole air injection part. Its complicated to explain.... I had to do it. I am not sure if it works because I have no bolted on the manifold yet.... It sure looks like it will though. I think I will test fit it tomorrow. No longer doing my D series project so I have parts all over lol
Old Mar 22, 2004 | 03:38 PM
does this help?
you will have to drill and tap the red hole, drill the green hole straight through, and drill the blue hole halfway through and then drill from the throttle body mating surface into that hole.
then you can use a normal 2 wire iacv, and any throttle body you want...
alacard
Dec 25, 2006 11:30 PM
FrostyDC4
Acura NSX
19
Dec 5, 2005 08:04 PM
Quade
Oct 5, 2003 11:27 AM
