Integra front rotor/caliper on '90-91 EX Knuckles....is this the way to go?
Old Mar 21, 2004 | 08:10 AM
Jonathan_ED3's Avatar
Default Integra front rotor/caliper on '90-91 EX Knuckles....is this the way to go?
I have the entire front knuckle assembly from a '98 Integra.
Now I've read that you can use the Integra front knuckles but that it throws off the geometry, and that the '90-91 EX knuckle is what you want to use.
Should I source 90/91 EX Knuckles and then just throw my Integra brake setup on it?
Or am I missing something?
Old Mar 21, 2004 | 05:34 PM
Default Re: Integra front rotor/caliper on '90-91 EX Knuckles....is this the way to go? (Jonathan_EH)
Just looking for some affirmation
Old Mar 21, 2004 | 07:44 PM
ls_vtec_crx's Avatar
the teg brakes wont fit...the caliper will hit the rotor with the pads in it....you gotta get the DA knuckles cuz the 98 ones wont be able to align right
Old Mar 21, 2004 | 08:07 PM
The Teg brakes won't fit what? The EX knuckles? Or the stock knuckles?
I've read that the DA knuckles screw up the suspension geometry, so if at all possible, I want a setup that will use the EX knuckles.
DC calipers don't bolt up to EX knuckles? Only DA will?
Old Mar 22, 2004 | 07:15 AM
ShiroX's Avatar
Default Re: (Jonathan_EH)
just get the 90-91 ex knuckles
then go to the autoparts store and order
90-91 ex rotors ($25-$30) each
90-91 ex LOADED calipers (will come with mount bracket to knuckle) ($45-$55)each
thats all you need and youll be set
im not sure about caliper interchange but pad are the same for the ex and integra
Old Mar 22, 2004 | 07:49 AM
Footwork's Avatar
90/91 EX Knuckles
Old Mar 22, 2004 | 07:57 AM
notfastenough's Avatar
Default Re: Integra front rotor/caliper on '90-91 EX Knuckles....is this the way to go? (Primo.)
http://www.ef-honda.com/ben/EFhybridsus.html
Hope this helps
Old Mar 22, 2004 | 09:01 AM
JSPECHB's Avatar
How the hell do you change just knuckles?
Old Mar 22, 2004 | 09:56 AM
EL Vap133's Avatar
Default Re: (JSPECHB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECHB &raquo;</TD></TR><TR><TD CLASS="quote">How the hell do you change just knuckles?</TD></TR></TABLE>
Just take off the calipers, rotors, and caliper bracket and slap it on the new set of knuckles.
Old Mar 22, 2004 | 10:20 AM
Default Re: Integra front rotor/caliper on '90-91 EX Knuckles....is this the way to go? (notfastenough)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notfastenough &raquo;</TD></TR><TR><TD CLASS="quote">http://www.ef-honda.com/ben/EFhybridsus.html
Hope this helps </TD></TR></TABLE>
Thanks for the link. That gives me some insight.
As far as using the EX knuckles, I know that's the way to go.
My question now is whether or not the DC/EM1 brake calipers bolt up to the EX knuckles?
Reason I ask is becauase I scored a mint set of '00 Si calipers for cheap.
I don't have any EX knuckles to test fit on, but I do have access to DA knuckles. I assume since the DA brakes fit the EX knuckles, then the brake system is the same.
Therefore if I try bolting up my calipers to DA knuckles that will give me an answer, yes?
Or if somebody knows off hand, that would be great too.
Old Mar 31, 2004 | 12:49 PM
cursED's Avatar
bump!
I've looking at DC (94+) calipers on EX knuckles as well. Anybody know for sure?
Old Mar 31, 2004 | 12:53 PM
EL Vap133's Avatar
Default Re: Integra front rotor/caliper on '90-91 EX Knuckles....is this the way to go? (milk)
I slapped on DC calipers, rotors, pads, etc on DA knucles and they went on perfectly.
Old Mar 31, 2004 | 01:39 PM
I can confirm that Integra calipers bolt right onto the EX knuckles. So do the 99/00 Si calipers...as they're the same as Integra calipers (and I've physically mounted both)
Finally found me a set of EX knuckles, so this isn't just theory.
I can get another set of EX knuckles in the next few weeks, if anybody needs a set.
Old Mar 31, 2004 | 02:05 PM
EL Vap133's Avatar
Good looking out man...
Old Apr 1, 2004 | 09:24 AM
cursED's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">I slapped on DC calipers, rotors, pads, etc on DA knucles and they went on perfectly. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_EH &raquo;</TD></TR><TR><TD CLASS="quote">I can confirm that Integra calipers bolt right onto the EX knuckles. So do the 99/00 Si calipers...as they're the same as Integra calipers (and I've physically mounted both)
I can get another set of EX knuckles in the next few weeks, if anybody needs a set. </TD></TR></TABLE>
Awesome! Thank you both!
Old Apr 1, 2004 | 09:27 AM
phan's Avatar
Default Re: (milk)
i myself am running da knuckles up front without any problems.
BadassEFdriver
Jun 2, 2010 10:58 PM
1net
Aug 18, 2008 06:16 PM
es.roadster
Feb 2, 2008 05:22 PM
Red_ED8
May 22, 2007 06:40 AM
philly-O
18
Apr 29, 2003 08:15 PM
