2000+ GSR ECU Swap - stock to stock, IMMOBILIZER problems...
Old Mar 21, 2004 | 08:08 AM
integra-modder's Avatar
Default 2000+ GSR ECU Swap - stock to stock, IMMOBILIZER problems...
My stock ecu isnt sending out an injector pulse so I need to get another one.
The way I see it is that when I do get the new ECU, it would have a new immobilizer key code, thus not letting the car start.
Anyone know of a cheap and good way around this?
Old Mar 21, 2004 | 08:18 AM
DISMANTLERGSR's Avatar
Default Re: 2000+ GSR ECU Swap - stock to stock, IMMOBILIZER problems... (integra-modder)
have same problem bought 01 gsr shell and i need an ecu for it so it can start
Old Mar 21, 2004 | 08:44 AM
VsR785's Avatar
i was trying to use an obd1 94-95 P72, i put it in an it didnt install...the car didnt start, i used my obd2 and it started...the immobilizer key **** prevents us from changing ecu's??? i'd like to know a way arouond that **** too...
Old Mar 21, 2004 | 08:47 AM
Kendall's Avatar
Default Re: 2000+ GSR ECU Swap - stock to stock, IMMOBILIZER problems... (VsR785)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VsR785 &raquo;</TD></TR><TR><TD CLASS="quote">i was trying to use an obd1 94-95 P72, i put it in an it didnt install...the car didnt start, i used my obd2 and it started...the immobilizer key **** prevents us from changing ecu's??? i'd like to know a way arouond that **** too...</TD></TR></TABLE>
No, an OBD-1 ECU won't run an OBD-2 car without a few necessary components. The ECU is encoded with an immobilizer, it's possible to have it removed though I'm not sure of the procedure. I personally thinks its just a better idea to convert to OBD-1, get a Skunk2 manifold and run a chipped P28.
Old Mar 21, 2004 | 09:05 AM
VsR785's Avatar
Default Re: 2000+ GSR ECU Swap - stock to stock, IMMOBILIZER problems... (Kendall)
so how can i convert to an obd1....i have a p72 obd1 ecu right now, wat else is necessary for the conversion to work?
Old Mar 21, 2004 | 09:06 AM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VsR785 &raquo;</TD></TR><TR><TD CLASS="quote">so how can i convert to an obd1....i have a p72 obd1 ecu right now, wat else is necessary for the conversion to work?</TD></TR></TABLE>
Search.
Old Mar 21, 2004 | 10:16 AM
Default Re: 2000+ GSR ECU Swap - stock to stock, IMMOBILIZER problems... (DISMANTLERGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DISMANTLERGSR &raquo;</TD></TR><TR><TD CLASS="quote">have same problem bought 01 gsr shell and i need an ecu for it so it can start</TD></TR></TABLE>
I think you can call up acura and explain the situation to them. The dealers have a database of all this info such as the codes and all that ****. If you have an o1 shell it should have the immobilizer receiver in place, so all you need to do is get a key (40 bucks) and have it programmed to your ECU's code. Once again, I would immagine that the dealer can do this if you bring the ECU to them or something along those lines.
Old Mar 21, 2004 | 10:20 AM
As Kendall said, the ODB I ECU wont work if you just plug it into an ODB II car. You have to get an expensive harness and all sort of ****. Depending upon what you want to do, will determine if you need this. For hondata, you need to run ODB I. I run my AEM EMS just by swapping, no work required. If you plan on just running VAFC and piggy backs like that, then just keep the ODB II.
Im not quite sure what the Skunk2 manifold has to do with changing your ECU, but the manifold is pretty good for the average driver. The JG/Edlebrock mani is mainly for high revving engines or massive amounts of boost.
Old Mar 21, 2004 | 11:35 AM
VsR785's Avatar
i do have a harness, but it think it may be the wrong one...is there a difference between the year of the harness? like between a 96-99 and a 00-01 harness?? if there is, i might have the 96-99 for my 01 shell.....fill me in somebody?
Old Mar 21, 2004 | 02:30 PM
Do more research on ECU's.
ODB I
ODB II
Old Mar 21, 2004 | 02:49 PM
B2FiNiTY's Avatar
Just get a OBDII -&gt; OBDI harness with an OBDI ecu and it should start without a hitch.
Old Mar 21, 2004 | 03:39 PM
VsR785's Avatar
Default Re: 2000+ GSR ECU Swap - stock to stock, IMMOBILIZER problems... (B2FiNiTY)
i got that, but i think i got the wrong one, b.c i tried to install it and my car didnt start...i got aobd2-obd1 harness, wired it to a p72 up to my 01 gsr, and it didnt start..maybe i have a 96-99 harness when i need a 00-01 harness.... ??
Old Mar 22, 2004 | 06:22 PM
99SlammedCivic's Avatar
Snipper Snapper
I am having the same Problem w/ my 2000 LS motor that i just put in my 99 ex civic...
car wont start w/ LS ECU , but will w/ the ex Auto ecu .... idels at 1700
LS motor is 5spd
Help me remove the immobilizer !
jdmwojo
May 31, 2011 08:59 AM
3rdgencrx
12
Feb 14, 2007 05:26 PM
NA JDM GSR
14
Jan 13, 2007 04:51 PM
tranceologist
Aug 28, 2005 05:05 PM
THE LORD OF CHAOS
Jul 5, 2005 01:34 PM
