ITR front / rear sway bar on EG
Old Mar 20, 2004 | 05:40 PM
Nothing.Special's Avatar
Default ITR front / rear sway bar on EG
Where can i buy this new? anyone know the part number and a general price?
also would i need or would you recommend anything else when using this?
Old Mar 21, 2004 | 09:43 PM
Default Re: ITR front / rear sway bar on EG (Nothing.Special)
anyone?
Old Mar 21, 2004 | 10:06 PM
chameleon's Avatar
keep checking the classifieds, or you can call up acuraautomotiveparts.org or something and order them. you can check out my intall how to on them @ http://www.jdmvtec.com
you will need a rear subframe reinforcement for the rear and ITR/GSR front/rear LCAs
Old Mar 21, 2004 | 10:49 PM
func-tion's Avatar
I know that it will gost over 150 to get all of the parts and brackets and lca's for the rear only.
Passwordjdm.com has the rears for 100.00 i think and all you will need is a set of 94-01 teg lca's.
For the front I would assume it would cost about the same ($150)if you are putting a sway bar on a car that dosent allready have one. But if you allready have one and you want to upgrade go to acuraautomotiveparts.net and you can get the bar,bushings and any other hardware to complete the swap.
EDIT the front swaybar alone costs 96.74 Some would argue that thats a unecessary mod if you allready have a front swaybar.
Also if you run rather soft suspension you will have to re-enforce the rear sub-frame or it may tear wich is really really bad.
dj theoretic
Suspension & Brakes
Dec 17, 2008 05:35 AM
gabspeed
Mar 17, 2004 04:39 AM
B_CRUZ!
Jul 9, 2003 05:35 AM
deviant1
17
Nov 3, 2002 11:40 PM
Dorikamu
10
Oct 27, 2002 10:10 PM
