OEM 6 disk changer
Old Mar 20, 2004 | 04:28 PM
fw190bvi's Avatar
Default OEM 6 disk changer
it was nice outside today (actually got up above 50), and i was bored as hell......so i decided to relocate the in-trunk cd changer into the cabin.......right now, its somewhat snuggly secured under the drivers seat, but thats not gonna fly for too long.......anybody got any ideas on where to relocate it/DIY mounting harness for it....(FYI, its just a bit too wide to fit into the center counsole )....
Old Mar 20, 2004 | 04:35 PM
FatJoe's Avatar
Default Re: OEM 6 disk changer (fw190bvi)
glove compartment
Old Mar 20, 2004 | 04:44 PM
fw190bvi's Avatar
Default Re: OEM 6 disk changer (FatJoe)
the only problem is the wiring, which appears to run through the frame up to the radio......
Old Mar 20, 2004 | 04:47 PM
FatJoe's Avatar
hmmm... you shoiuld ask in the audio forum...might get some better feedback there. good luck man.
Old Mar 20, 2004 | 04:58 PM
Hondaaccordvtec's Avatar
Hey, to give you an idea, here's my 6 disc in the glove box.
Install was pretty easy, just time consuming and locating/hunting the right materials.
Enjoy
Old Mar 20, 2004 | 05:05 PM
fw190bvi's Avatar
Default Re: OEM 6 disk changer (Hondaaccordvtec)
ok....does anyone know if the that runs between the stero head unit and the changer is routed though the frame???......if it is, how much would a wire like that go for???.....cause im assuming i could hook a new one up to my head unit, then route the wire from their....i like the glove box idea....BTW, how did u fill in all that open spave in the glove box, and im not just talking about the plastic cover which i assume you cut yourself.....
Old Mar 20, 2004 | 05:07 PM
FatJoe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaaccordvtec &raquo;</TD></TR><TR><TD CLASS="quote">Hey, to give you an idea, here's my 6 disc in the glove box.
Enjoy </TD></TR></TABLE>
dayum...thats nice and clean, props on the install
Old Mar 20, 2004 | 06:06 PM
The wire you are talking about should be accessible by removing the center console to find were it is routed. I'm assuming this is an Alpine M-Bus changer? You can easily purchase a smaller M-Bus cord if you want to relocate it to the glove box. A 6 footer should do nicely.
Now as for how I filled in the space. I didn't, the changer is mounted with 2 bolts to the upper part of the glove box. In order for me to make it fit, I had to dremel out the back of the glove box and then 'glass it back over to accomadate the bump out I made in order for the changer to fit properly (don't want anything messing itup in the back - no easy access). Then I made a template out of paper for a rough opening to cut the ABS plastic sheet I had. I then used black caulk to fit it in place securely. Added the trim ring around the changer to hide some screw ups and presto! Custom mounted changer in the glove box.
I had to find a plastics company in my area to get the rough material and then I went to AC Moore (arts and craft store) and spent some time looking for the right trim pieces I needed to finish it off.
HTH - any more ?'s, let me know - I'm here to help in any I can.
tylerg6254
Audio / Security / Video
Sep 28, 2016 10:53 PM
White95SiHB
May 26, 2011 08:18 PM
dust_101
May 23, 2006 07:18 AM
Thirty-Nine
Jan 10, 2004 01:02 PM
